Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 09-20-2020, 02:14 PM #346
Tank is out.
Old 09-21-2020, 04:20 PM #347
My 1997 SR5 build and repair thread
Part looks ok parts don’t. It’s going to be fun.
Old 09-21-2020, 04:40 PM #348
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's all rotted off. The bottom of the frame rotted away. That's what I expected to see with how the bracket came loose. :[
The steel gone 50% up both sides or more?
As it be best to get rid of the rot.
Worst case. You can clean the top of the inside frame and plate it for increased strength. Then cut the sides off one at a time. Replacing the steel down to the bottom. Once all back in there weld your covers over.
You see why I basically build a new U in the frame. As you have to have steel to weld too.
Old 09-21-2020, 05:09 PM #349
I’m still forming a plan. The sleeve is 11 gauge and seems thicker than the frame thickness.
I need to cut the bad stuff away all the while not letting the frame sag while doing it.
I wish I had my garage wired for 240v I’d fire up my compressor and sandblast the inside and then paint it with ZeroRust.
Old 09-22-2020, 07:49 AM #350
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. Nothing wrong with thinking on it a few days. Welding a plate on the top rail will secure it. By the looks of your top rail its intact and solid at this point.
Could rebuild the sides get those secure again then cut the old sides off. I mostly do one side at a time. So to make sure the frame stays at the same point. Not a good idea to chop both sides completely off as bending can occur.
Old 09-22-2020, 05:59 PM #351
So I think my plan is going to be removing the bad steel and rust proofing what I can and slipping the sleeve over what’s left of the frame and weld it in place. It’s 35 inches long and 1/8” thick. I’ll end up removing all the rear brake line mounts plus the gas tank spacer block bolted to the frame.
I really think it would be overkill repairing the frame and then installing that sleeve.
I’ll also run a magnet in the frame and remove all the scale that flaked off.
I will paint the inside of the sleeve with ZeroRust.
Old 09-22-2020, 06:46 PM #352
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good plan.
Old 09-23-2020, 02:38 PM #353
Test fit
I need to bolt up the lower control arm to make sure I got the position correct.
Old 09-23-2020, 03:00 PM #354
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Well hey! That is looking good! How does the other side look?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 04:32 PM #355
The frame is cleaned and sprayed with a zinc primer. As well as the inside of the sleeve. I pulled all the rust scale I could out of the frame with a magnet.
Tomorrow my goal is to install the sleeve and bolt up the LCA and put it in it’s permanent resting place. When I finish my work stretch next week I’ll weld it in place.
I ordered the tank strap and picked up the pickup filter. I need to order gaskets for pulling the pump assembly yet.
Old 09-23-2020, 05:58 PM #356
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looking good
Old 09-24-2020, 12:04 AM #357
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
You work way faster than me! Have you thought about doing an internal frame coating while you've got easy access?
Something like this?
Eastwood Internal Frame Coating Aerosol Spray (14-oz.)
Build
Old 09-24-2020, 08:42 AM #358
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Dont waste your money in the heavy rust belt with Eastwood coatings. I dont think the internal frame can get descaled and clean enough for these products to work properly. I used that product and went into the frame a year later and it was rusting again.
Old 09-24-2020, 11:33 AM #359
I start my 12hr shift tomorrow morning. So work will be on hold until next Wednesday when I start my 5 day off stretch again.
I still worry about getting that sleeve in the proper spot so it doesn’t move the axle.
I will flood the frame with fluidfilm or something like it. The jeep people like using linseed oil.
Old 09-27-2020, 08:06 PM #360
Can someone out there give me some help?
I need a reference point measurement from the lower control arm mount to a point on the frame.
I’m going to start welding the frame repair sleeve in on Wednesday and want to be as accurate as possible.
If both frame rails are identical I may be able to use the passenger side to accurately place the axle.
1997 Build Thread amcnult1 3rd gen T4Rs 2 07-12-2014 10:04 AM
Bvrr0's 1997 sr5 build thread bvrr0 3rd gen T4Rs 19 03-06-2014 11:08 PM
Sleeper's blue smurf build/repair thread sleeper17 3rd gen T4Rs 55 05-11-2013 02:02 PM
Tye's '87 Runner Build and repair thread mytyeerinpie Classic T4Rs 84 06-24-2012 08:43 PM
repair/ build thread 95 4runner hondaracer11 Classic T4Rs 43 09-16-2011 12:33 PM
