Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 02-13-2021, 09:06 AM #421
This battery is far better. No lazy cranking after sitting overnight and within a minute of engine run my alt is only pushing 14a. Which means the battery is not needing recharged after sitting overnight.
Old 02-16-2021, 01:22 PM #422
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
That's great! I just went through the same thing with my Prius. I went through so much trouble trying to pin down a parasitic drain, but it was just a bad battery.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 03-21-2021, 05:11 PM #423
My 1997 SR5 build and repair thread
Stump pulling
Old 03-25-2021, 03:21 AM #424
dork0900 dork0900 is offline
dork0900 is on a distinguished road
That picture is leaving us stumped
dork0900 is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 06:54 PM #425
Well I have been hearing a jingle sound in the drivers side and had narrowed it down to the front wheel assembly.
The brake pad scraper was touching the rotor.
I discovered that inner inner Tie-Rod on the passengers side is dead also.
It’s nice to know pads on this rig can be changed without removing the caliper.
I do need to figure out if the pins are coated. I had to descale them to remove them. If OEM ones are coated I’ll get new ones so the pads float better.
When I bought this rig as my project it seemed like the PO had just put new pads and calipers and rotors on. He left the boxes with the old parts in them in it when I towed it home. 30,000 miles and the pads are shot. Interesting.
Old 04-16-2021, 06:12 PM #426
Prepping to replace the inner tie rod on the passenger side. Measurements to hard parts of the frame to try and avoid another alignment.
Old 04-17-2021, 11:15 AM #427
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I thought the inner tie rods thread onto the rack all the way. Why would you need to know the rack to inner tie rod distance?
Old 04-17-2021, 11:36 AM #428
So I can put the steering wheel to the exact place as before to get the toe set exactly where it was before. I’m figuring the steering wheel is going to move a little wrenching on it.
Old 04-17-2021, 11:45 AM #429
Real Name: Patrick
Real Name: Patrick
So are you tightening the inner tie rod end all the way in or are you putting it back in the same spot? I can't remember if there is a lock nut or anything to hold the inner tie rod from unthreading.
Old 04-17-2021, 11:51 AM #430
There is a key’d washer between the rack shaft and the inner tie rod. After tightening the new inner tie rod to the rack you hammer the washer against the flats of the inner tie rod. That keeps it in place.
Edit. Here is the key’d washer
Old 04-17-2021, 02:39 PM #431
Starting to put it back together.
The piece of lock wire it to put the outer tie rod back in the same place.
It only took one wack on the monkey wrench to break it loose from the rack.
Old 04-17-2021, 06:06 PM #432
I will most likely do the drivers side while I have 2 weeks off for vacation and get another alignment done.
Old 04-18-2021, 10:21 PM #433
Since my steering wheel was strait before the new inner tierod replacement I drove around with tools and kept adjusting the Tierod until my steering wheel was strait ahead while driving. Drivers side has zero play so I’m putting it off for now.
Old 05-02-2021, 10:35 PM #434
Everytime I buy 89 or higher I seem to get better fuel milage. So I’m going to run 89 for a few tanks driving to work.
This tank I had 54 miles of local driving before I started my work stretch and I got 21.5mpg. I’m currently at 60 miles and I’m still on the 3/4 tank mark. I will drive it for work the next two stretches and see what I get.
Old 05-03-2021, 09:15 AM #435
This rebuilt engine had the heads and block decked around 16 thou total so that bumped up the compression and @ mentions that Toyota only looks for knock above 3000rpms.
I’m also thinking of heat range 6 plugs to go one step colder.
1997 Build Thread amcnult1 3rd gen T4Rs 2 07-12-2014 10:04 AM
Bvrr0's 1997 sr5 build thread bvrr0 3rd gen T4Rs 19 03-06-2014 11:08 PM
Sleeper's blue smurf build/repair thread sleeper17 3rd gen T4Rs 55 05-11-2013 02:02 PM
Tye's '87 Runner Build and repair thread mytyeerinpie Classic T4Rs 84 06-24-2012 08:43 PM
repair/ build thread 95 4runner hondaracer11 Classic T4Rs 43 09-16-2011 12:33 PM
