Old 12-24-2016, 06:31 PM #1
dustxking dustxking is offline
dustxking is on a distinguished road
Passenger floor is soaked! 96 sr5
I got weathertech's for Christmas and installed them today. Come to find out my passenger floor board is soaked.
It is only wet right in the dead center, not up under the dash or where the seat is bolted to the floor. Only dead center. The sun roof isnt wet or leaking, nor is the door seals leaking or bad. I pulled the carpet up and looked under the carpet and there is no bolts/grommets that are loose. I am stumped. Anyone have any experience with this?
dustxking is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 06:42 PM #2
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Sounds like a possible heater core leak. Any sweet coolant smell inside the rig?
BrianK14 is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 06:56 PM #3
GGFerrier's Avatar
GGFerrier GGFerrier is offline
GGFerrier is on a distinguished road
GGFerrier's Avatar
Mine was the passenger side firewall plug. I ran a bunch of wire through it and there wasn't a good seal anymore. Clear it up and sealed everything up with Marine sealer. Nice n dry.
During my research I found some people saying it could be the windshield seal too.
Ultimately I pulled the carpet up and ran a hose over different areas and found where it was coming from.
GGFerrier is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 06:57 PM #4
Not at all, this runner is fairly new to me. 185k i got it just under 2,000 miles ago. It has snowed and rained alot here in the PNW the last few weeks, but no one that I remember has sat there for a long time. Coolant levels are perfect too.
Old 12-24-2016, 08:05 PM #5
reelamin's Avatar
reelamin reelamin is offline
reelamin is on a distinguished road
reelamin's Avatar
As said earlier....the carpet is up....hose it down and it will show up. Lots of places it could be leaking from. I'm guessing the center is the absolute low spot so it is just collecting there.
He who Shi% fast does not Shi% for long!!
BILSTEIN CUSTOMER SERVICE SUCKS MUNG COVERED BALLS!!!
reelamin is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 09:01 PM #6
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Doesn't the sun roof drain tube runs on passanger side ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 10:09 PM #7
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
This.
If the drains get clogged, the water will overflow onto your headliner, run down your a-pillar, and soak your floor.
I'm willing to bet this is your issue- it happened to me, so I know it's a possibility. Open your sunroof, and make sure the drains are clear- there is one at each corner.
Do you happen to park on a down-grade regularly?
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 10:47 PM #8
nissanh nissanh is offline
The center of the passenger floor is the lowest spot so any water may rest there. How is the AC drain? It may be clogged and leaking between the blower motor and evaporator joint.
Old 12-25-2016, 01:04 PM #9
Tam4511 Tam4511 is offline
Tam4511 is on a distinguished road
Yup moonroof drains, common on any car with a moon roof
Sent from my SAMSUNG-SM-N910A using Tapatalk
Tam4511 is offline   Reply With QuoteReply With Quote
Old 12-27-2016, 12:07 AM #10
Originally Posted by Tyler James Inc View Post
This.
It is the drains. I don't know yet if it is a hole in the tube. Or clogged drains. Yes I park on a down grade driveway with the car facing towards the sky.
What is the best way to unclog if that is the case.
Old 12-27-2016, 12:15 AM #11
Hm, more likely if it's facing down the grade, where the water will flow toward the front of the vehicle. But still possible. Like someone has brought up; the floor board is the lowest point, so it really doesn't point to any point of entry.
That being said- to clear the drains on mine, I opened the sunroof all the way, and scooped all the gunk out of the "gutter" to expose the glorious drains. I then proceeded to strip my whole interior, and replace my headliner to get rid of the black mold that started growing when my drains were clogged...
Old 12-27-2016, 02:51 PM #12
Ok so this little tube is soaked. I got up and cleared the two front drains. But now only time will tell.
For the life of me though I cant figure out where this little tube is connected. Any info?
Passenger floor is soaked! 96 sr5-file_001-jpg  Passenger floor is soaked! 96 sr5-file_000-jpg
Old 04-10-2017, 10:57 AM #13
St0neWhite's Avatar
St0neWhite St0neWhite is offline
St0neWhite is on a distinguished road
St0neWhite's Avatar
Dude ! I had the same problem with a wet floor board.
That lil tube is the line to the rear windshield wiper fluid.
Mine was disconnected for the longest time. From time to time I would run my rear windshield wiper just to see if could get it to work, little did I know I was shooting windshield wiper fluid under the padding and carpet....
Anyhow, now reconnected tube, no wet carpet and my rear windshield wiper fluid sprayer works ! Passenger floor is soaked! 96 sr5happy day, hope this helps.
St0neRunner Build: http://www.toyota-4runner.org/3rd-ge...0nerunner.html
Deck plate mod, high flow filter, pulstar plugs, 3" lift w toytec coil overs, diff drop, Highflow cat, mangan flow muffler, built in cargo box, air compressor, custom built bumper, modified roof rack, Remote control gobee lights, hood scoop led light, bluetooth, gps, cb, obdII reader, new leather seat with seat heaters installed. Many hrs of maintenance and suspension part replacement
St0neWhite is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 12:01 AM #14
Philz Philz is offline
Philz is on a distinguished road
Same here!
For years I couldn’t figure out where floorboard moisture was coming from.
Yesterday I pulled back carpet looking closely finding that tube disconnected.
Anyway , no more worries of leak coming from behind glovebox-firewall area potentially getting ECM wet.
96 4-Runner Limited
Philz is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 04:06 PM #15
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
[snip]
i love answers that just nail it! thanks. i will keep this in mind should i ever have a puddle.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
passenger floor soaked westtex 4th Gen T4Rs 12 06-23-2015 03:49 AM
Passenger side floor wet phishtaco 4th Gen T4Rs 1 12-06-2013 11:22 AM
Water build up in my passenger side floor and behind passenger seat a4runner97 3rd gen T4Rs 12 03-23-2013 01:48 PM
HOT floor under passenger seat? dog 4th Gen T4Rs 3 07-28-2012 08:44 PM
WTB: 4th Gen Passenger OEM All Weather Floor-mat noiwontsmile Want to Buy/Trade 1 02-28-2012 11:38 PM
