12-29-2016, 11:57 PM
3rd gen roof strength? Gobi or Baja rack
Questions for any of you with a Gobi or Baja rack mounted to factory side rails.
How's your roof holding up? Any roof strength issues? I've read through and searched posts and I'm on the fence about somehow reinforcing the roof before I mount my Gobi rack. Is it necessary or will the 3rd gen roof really hold up to carrying cargo or using a roof top tent?
I'd like to hear from people who have used, and maybe abused, their roof racks that mount to factory side rails.
12-30-2016, 12:19 AM
I loaded down my Yakima setup and had no troubles. Probably 300lbs in the basket on the factory location and another 2-300 tied down to the front Q towers. No issues at all.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
12-31-2016, 09:10 AM
Anyone using a roof top tent have issues with the T4R roof holding up?
01-01-2017, 12:01 PM
Official Vendor
Official Vendor
Are you concerned about the side rail mounts, or the forward legs?
When I did mine and Coward's racks my concern was the strength of the roof at the forward legs - which as it turns out was unnecessary, as the roof sheet thickness is significant above the A-pillars (I drilled pilot holes there to install rivnuts for bolting the front legs to the roof and was surprised to see that the steel looked like 2+ mm thick at casual glance...)
- on the other hand; I did see one rear corner of the roof flex a bit when Coward was standing on that part of the rack - and he's probably 160 pounds, I guess?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2024
01-01-2017, 03:24 PM
I'm mostly concerned with the siderail mounting points buckling under the weight of a couple people or gear.
01-01-2017, 03:26 PM
Each of my factory crossbars had little stickers that said 160lbs max. Using that logic I've loaded mine down with 300lbs up top without issue. Mine isn't a "Gobi" but it's the same design.
01-01-2017, 03:51 PM
Official Vendor
Official Vendor
So I just happen to have headliner out at the moment:
You can see the stamped steel "rail" that runs along underneath the roof, and the two cross bars at the rear of the rails.
Where the forward mount of the rail section of the rack would be does not have a cross bar (just in front of C pillar)
The forward mount would have been my concern, but it carried Coward's body weight better than the rear corner, for whatever reason...
Hope that is helpful?
keith
eimkeith.com
01-01-2017, 07:19 PM
I've run around on mine too....I'm 220 lbs. No flex or issues. I think the roof, while really thin, is pretty strong. Now, the middle might not be, but around the edges (where my rack is attached) appears to be strong enough for just about anything you could conceivably stick up there.
01-01-2017, 07:42 PM
Real Name: Miguel
Real Name: Miguel
Is the consensus that you could put a RTT with 2 adults and some dogs with no worries of weight issues?
2001 Toyota 4Runner SR5 4X4
01-01-2017, 10:11 PM
There are lots of pictures on Instagram where 3rd gen owners are using RTTs on their rigs. I have a CVT Mt Shasta Extended coming this week that is going on top of my 3rd gen.
01-01-2017, 10:36 PM
Real Name: Miguel
Real Name: Miguel
I've seen them here on the form. Doesn't mean the truck is really capable of doing it.
Like 35's. They can fit but it isn't really good for the trucks, so far as I have seen.
01-01-2017, 10:39 PM
Official Vendor
Official Vendor
How much does the RTT weigh?
My rack is 90lbs by itself; so if the factory setup is rated for 320, then would that leave 230 pound capacity for RTT + occupants? - or is that not applicable to a static load? (my assumption)
keith
eimkeith.com
01-01-2017, 11:23 PM
Real Name: Miguel
Real Name: Miguel
The tepui Kukenam SKY Siberian Camo comes in at 130 lbs. that's a 3 person tent which is probably what I would get.
I would assume that the weight is based on static loads. I don't think the roof can do dynamic loads. I could be wrong though.
01-01-2017, 11:24 PM
If you are looking for a factory recommendation about it I have never seen one.
Everything I have read about those weight rating are in regards to weight capacity while the vehicle is moving. All the aftermarket rack companies tend to list static loads much higher than moving loads. Going back to the examples; there are other rigs using aftermarket racks and RTTs with multiple occupants for numerous seasons.
01-01-2017, 11:50 PM
Thanks everyone for all the input! I'm going to brave the roof strength and mount up the Gobi. I actually am mounting a Gobi rack for a 1st gen Sequoia. I like the wider rack. It should be about the width of the upper door openings instead of the factory rail area. I'll report out how it goes.
