12-30-2016, 04:04 AM
King? Fox? Icon? Sway-a-way?...
Looking to upgrade my suspension from the bilstein 5100. What's you guys opinions on those brands and any other I might be leaving out?
12-30-2016, 04:06 AM
Planning on standard length, daily driving and occasionally light off-road trails once a month or every other month. Looking towards 2.5s with or without reservoirs
12-30-2016, 04:08 AM
Love my Fox 2.5's on my daily. Ride is great. Handling is great even with disconnected front sway bar, and it soaks up a whole lot of abuse, I've done a few decent sized jumps messing around and the front just irons it all out. I had the 5100's before and they were good, but the Fox's are a whole new level. I'm not as happy with the ICON 2.5 Piggybacks I have in the back, but they were well used before I ever got them, so you may be better off if you get new ones.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
12-30-2016, 04:21 AM
Yeah people have been telling me it's night and day coming from bilstein to fox/kings/icon/SAW. Are your fox the one with the resis or non?
12-30-2016, 04:22 AM
2.5 Resi, standard travel with 600lb eibach springs
Sent from my Z958 using Tapatalk
12-30-2016, 11:50 AM
Buy whatever's cheapest as they are essentially all the same.
12-30-2016, 12:10 PM
The Kings look the coolest
12-30-2016, 12:19 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
All the 2.5 coilovers for our rigs are built pretty much the same and for the most part share common internals. I don't think you can go wrong with any of the major brands. Just depends what you can get for the better price.
Personally, I love my older 2.5 SAW's but since the company got bought out by AFE I probably wont buy anymore sway-a-way stuff. I'd probably go King.
Also, check out a company called ADS racing.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
12-30-2016, 12:40 PM
Bilstein has a 2.5 shock now, I'll probably switch to that when my 5110's wear out.
http://www.toyota-4runner.org/genera...ock-guide.html
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
12-30-2016, 01:31 PM
I upgraded from the 5100's myself to the Icon 2.5's. I have no complaints at all. I was between the King and Icon but ended up get the Icon's for almost $300 cheaper.
2001 4runner: Supercharged, E-locker retrofit, Icon ext travel coilovers, SPC UCA, LC 8 wraps, LC Tokiko blacks, 1" BL, CBI front bumper, 8k warn winch, Shrockworks sliders, 285 KO2's, TBU, TRD Pro wheels, Projector Retrofit, 23" Light bar, and Scanguage II. My Build
1995 Land Cruiser: Factory lockers, TRD supercharger, CDL switch, and 7 pin mod.
2016 4runner Trail Premium SOLD
1999 Honda Civic DX (Daily)
12-30-2016, 07:17 PM
Hi,
are the Fox, King or ADS shocks DIY-rebuildable? Or do I have to send them to a specialty shop or their manufacturer for a rebuild? Also, are these shocks' rebuild parts available easily?
Thanks.
12-30-2016, 09:01 PM
I believe I'm the first to run these (or at least to my knowledge) Bilstein 8125 remote Resi. The most accurate thing I can say is Holy Sh**!
1996 4Runner - 3RZ - 5 Speed| Lot's of guinea pig installs, and parts. | Bilstein | Superwinch| Marlin Crawler| Front-Range Off-Road|Addicted Offroad| DIY Fabrication & Engineering
12-30-2016, 09:04 PM
Originally Posted by HiluxSurf SSR-G
Hi,
Thanks.
Those are all rebuildable. Parts can be sourced through dealers, and you would need to find a shop to charge them with nitrogen once the rebuild is complete!
12-30-2016, 09:28 PM
Real Name: Dylan
Real Name: Dylan
If you want to build up a good setup then FOA. You'll have to do measurements but they have some good stuff.
12-30-2016, 09:55 PM
Um, I know some people have had success with FOA, but I know of more that tried FOA and went with King, SAW or Fox. YRMV.
1998 4Runner Limited, King coilovers, Trick Toys Fab front bumperette/lightbar, TTF rock rails, Toyo 265's, locker mod.
