With just rear springs, you're only raising the ride height, not lifting the suspension. If you had a bracket lift then you would need different shocks.
The regular icon 2.5 shocks will work with your current setup. make sure you get a longer brake line as these shocks will let the axle droop out farther than stock. The stock brake line will act like a limit strap until it breaks.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
