Originally Posted by phattyduck
Just put in all distilled water, drive it a day, drain and fill with water only again, then fill with a gallon of red and top it off with distilled.
That is, assuming it won't freeze while you are doing this process.
You dont even have to drive it for a full day but it is more conveniant that way, after draining and filling with distilled water, just run it for about 10 mins running the heat and when the thermostat opens up the coolant in the core and block will flush...
i bought 5 gallons of distilled water (very cheap) and flushed my system using evapo-rust to get rust out of the block and cooling system, done with the engine running being sure never to let the rad. become empty...I did have to shut it off once or twice to let everything cool down and take a break, but after running 5 gallons of distilled water/evapo rust the coolant was draining clear and then I filled it with prestone EG coolant, didnt use the red stuff...
dont forget to burp the system too
I also used evapo rust and distilled water in the resovoir, let that stuff set in, flushed it with distilled water and cleaned it out as well
