01-18-2017, 07:28 PM
Real Name: C8H18 Mike
Airaid Intake Mod
Looks like my factory intake duct/hose from the air box to the throttle body is cracking in several places and may even be leaking.
Other than sealing the airway, what are the benefits of the airaid intake tube, and is it worth $137?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
Reason: fixed stuff
01-18-2017, 07:44 PM
Yeah sealing the cracks would be good but ya' know the factory already put a "cold air intake" in place via the snorkel going into the right fender.....
Personally, I'd use my $137 on something else, maybe beer....
01-18-2017, 07:54 PM
That might not be a lot of beer considering all the craft, high ABV microbrews out there, but point taken!
How about $12 on a deckplate mod to let 'er breathe more?
it's the same as the ISR, just with a mass production. and pricetag.
2000 4Runner SR5 Sport
1998 Lexus LX470
01-18-2017, 08:05 PM
You can change your spark plugs without removing the intake tube if you have the Airaid intake installed. Guess they raised the price of it, I got mine for $99 from Low Range Off-Road a couple years ago.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
01-18-2017, 08:07 PM
Originally Posted by octanejunkie
Looks like my factory snorkel from the air box to the throttle body is cracking in several places and may even be leaking.
"snorkel" from air box to TB? Not plain intake duct/hose?
I just fixed mine with 10-mil, 2-inch wide vinyl pipe cover tape. Will roll like that until I do my battery -intake swap.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
01-18-2017, 08:17 PM
Fixed that, thanks
For $137 I can roll tape all day long...
01-18-2017, 09:27 PM
Fixed that, thanks
And buy lots of this...
01-18-2017, 10:11 PM
If you buy cans of beer you could cut and tape your own CAI and enjoy the "work" to fabricate it.
01-18-2017, 10:42 PM
I installed this setup when I first bought my 4R because the factory setup was busted up. I like how clean it looks, makes swapping spark plugs much easier, and removed unnecessary "stuff" from under the hood.
I just had to skip a few high ABV craft beers the next month to make up the difference. A year later I do not regret the decision. YMMV and IDGAF.
07-03-2019, 12:44 PM
Real Name: Cass
Real Name: Cass
Cracked air filter housing
Can a large crack in the plastic box that houses the filter, cause any noticeable issues? The crack is after the filter. Thanks
07-03-2019, 01:24 PM
I have one. Clears up a lot of clutter as tx_shooter mentioned. With the exception of the airraid stamp, it looks like factory.
07-03-2019, 01:50 PM
Real Name: Jerod
Real Name: Jerod
Depends if it's before or after the MAF. If any part of it is after the MAF, then yes, it won't read the airflow correctly.
Of course there's also the issue of unfiltered air coming in which could be bad if you drive in dusty conditions.
07-04-2019, 08:35 AM
yeah same here, used a toyo ($38) part for the piece closest to the throttle body, no more lean codes or stuttering.
