Old 02-21-2017, 07:33 PM #16
Skurvy_Pirate Skurvy_Pirate is offline
Skurvy_Pirate is on a distinguished road
@echoplex301 and @wemslie97 I am pretty confident it is not the actuators. I can lock/unlock all doors fine when using the key in the driver side door or rear hatch. Also when starting/stopping the ignition they will all lock/unlock.
@ambush I think that is the issue. I remember searching a while back when I was annoyed by the door lock buttons not working and saw something related to that. I had checked all fuses/connections but didn't go further. I will look into replacing the junction box, seems pretty spendy though. Maybe a wrecking yard will have one.
Skurvy_Pirate is offline   Reply With QuoteReply With Quote
Old 09-18-2017, 12:27 AM #17
gstai's Avatar
gstai gstai is offline
gstai is on a distinguished road
gstai's Avatar
Bringing back an old thread...
Was this ever figured out? I have the exact same problem. All my door lock motors are new, the fob only locks the doors, and it will not lock nor lower rear window down. I have replaced the relay unit inside with a junkyard one and nothing changed. I am wondering if it is related to wiring gone bad in the doors or relays on the module that have gone bad. Just wondering if anyone has any advise?
2000 Manual 3.4L v6 SR5 w/ K&N Intake, Toyotec Adjustable Coilovers, OME 906, Nitto Terra Grapplers 285/70R17, Procomp 7005-7983, Diff Breather Mod, Scanguage II
gstai is offline   Reply With QuoteReply With Quote
Old 09-18-2017, 12:06 PM #18
I never resolved it, but I haven't tried the replacing the junction box yet just because of the price and the issue really isn't worth that much to me to fix.
Old 08-26-2018, 07:09 PM #19
aTALLasian aTALLasian is offline
aTALLasian is on a distinguished road
Was the root cause of the issue ever figured out? I'm also having the exact same problem. I tried re-pairing the remote to the system but that was a no go because the unlock button is needed in the programming and the truck no longer recognizes that it's being pressed. I've verified that the remote is broadcasting a signal at the auto store, but I'm wondering if the remote is the issue none the less. Everything else related to the security system is working (lights, beeps/horns, locks when put in drive and when turned off, etc), which leads me to believe that the remote isn't pumping out the correct signal anymore.
aTALLasian is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 03:01 AM #20
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
You can now add me to this list.
The 2 fobs I have lock the doors pretty much every time but the unlock only work every now and then.
With both fobs doing the same - I have to believe the issue is elsewhere.
(No alarm - just original fobs)
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
keyless , remote , unlock
99 Factory key fob/alarm locks but won't unlock doors Rocket3004 3rd gen T4Rs 7 02-13-2023 12:15 AM
Door Locks; auto unlock? wvuviv30 4th Gen T4Rs 11 04-14-2020 08:06 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 8 11-25-2013 08:51 PM
Power locks won't unlock (but locking works) abw73 3rd gen T4Rs 5 11-18-2011 05:39 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 2 04-25-2010 12:42 PM
