Old 01-21-2017, 09:48 PM #1
Skurvy_Pirate Skurvy_Pirate is offline
Skurvy_Pirate is on a distinguished road
Keyless remote only locks, does not unlock
I recently replaced the battery in the keyless remote that we have after not using it for years. But the car only responds to the lock button and not the unlock button. Does this indicate a problem with the remote or possibly with the programming? Or has anyone else seen this?
I also have another issue with the power locks in that the buttons on both doors do nothing. Locking/Unlocking when starting the car or using the key in the lock works fine though. I think this might have to do with the fuse panel though from what I have read. Just giving info in case they might be related.
Skurvy_Pirate is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 11:09 PM #2
Anyone have thoughts on this?
Old 01-31-2017, 01:30 AM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Not saying it is your case but I had this issue and it turned out to be that the tension tabs holding the battery inside the fob had lost tension over the years. I removed the battery and bent them so good contact was restored and all'ls well.
As I prefer to troubleshoot rather than guess, may I suggest you find an auto parts store with one of those gadgets for testing fobs. They light up when they receive a signal from a fob. Good way to test if the issue is in the fob and it's free to use. My NAPA has one on the counter.
My Backyard Frame Swap
Old 01-31-2017, 01:42 AM #4
fblainen11 fblainen11 is offline
fblainen11 is on a distinguished road
It's probably not a programming issue. You don't program the buttons independently. The fob is either programmed or it isn't (at least from the fob perspective).
I'd get on Amazon and order a new fob. Aftermarkets look exactly like OEM and I've had good luck with them. Probably around $10-15 bucks. Then look up programming directions online. Easy fix.
It MAY be an issue with your vehicle procession the signal, but I doubt it. You could go through the trouble of troubleshooting, or buy a new fob and program it and you'll know for sure that way.
fblainen11 is offline   Reply With QuoteReply With Quote
Old 02-01-2017, 12:52 AM #5
Oh nice! I didn't know auto parts stores had those available to use. That sounds like the best/easiest thing to check first. That will at least tell me if it is the FOB or something worse. Thanks!
Old 02-12-2017, 10:31 PM #6
Tested it at an auto parts store and all the buttons are active and working, so it looks like something more complicated is going on. The Unlock and Back Window buttons don't do anything for the car, only the lock button does anything.
Any ideas on what I can check next? I read that there is a fuse/relay panel issue that could cause the auto lock buttons to not work, maybe it could effect the remote as well? I would expect no buttons to work in that case though...
Old 02-12-2017, 11:05 PM #7
wemslie97's Avatar
wemslie97 wemslie97 is offline
Real Name: Bill
wemslie97 is on a distinguished road
wemslie97's Avatar
Real Name: Bill
You didn't specify your year your tr4 is but I have a '97 and '96-'97 key fobs have only 2 buttons; one button that locks/unlocks the doors and a second button that does nothing until you buy a second '96-'97 runner and then it will unlock/lock the doors on that vehicle. There was no window up/down button until '98 or'99 I believe. The rs3000 can be programmed to lock the doors when the ignition is on but it can be disabled. Hope this helps?
'97 T4R LTD 4WD desert dune, bone stock, factory E-locker, RS3000, Scangauge II, Hella 450's, 191k
wemslie97 is offline   Reply With QuoteReply With Quote
Old 02-13-2017, 05:00 AM #8
Sorry, this one is a 2000 that is having the issue. The auto door locks work when I start and turn off the car, or use the key as well. But there is something funny going on with the FOB/door switches.
Old 02-13-2017, 07:34 PM #9
wemslie97's Avatar
Real Name: Bill
wemslie97's Avatar
Real Name: Bill
My guess then is it's your key fob. The working button confirms the signal going to the onboard sytem and the door locks, unlocking or locking use the same mechanisms on the vehicle.
Old 02-13-2017, 07:51 PM #10
But I tested the fob at an auto parts store and it was sending signals for each button press.
Old 02-13-2017, 11:22 PM #11
wemslie97's Avatar
Real Name: Bill
wemslie97's Avatar
Real Name: Bill
That's pretty baffling. Have you tried resetting the RS3200? Here's a link to the manual for that security system.
https://www.manualslib.com/download/...ta-Rs3200.html
Old 02-19-2017, 03:44 PM #12
Which part would you recommend I try? I didn't see a generic "reset" section, but more about changing behavior (Unlock drivers door vs unlock all doors, etc). Another thing to note is that the lock switches in the doors don't work, and both this and the remote programming instructions use them as part of the procedure. So I am not sure if I would be able to do it even if I wanted since I won't be able to do some of the steps.
Old 02-19-2017, 10:40 PM #13
echoplex301's Avatar
echoplex301 echoplex301 is offline
echoplex301 is on a distinguished road
I had a similar problem with my '00 4Runner. Have you verified that it's not the door lock actuators going bad and not the key fob?
My issue was I couldn't program my new fob because two of the four locks would start to get lazy during the lock/unlock cycling that's required to enter programming mode. After a few locks/unlocks both front door locks would only unlock halfway. Turned out to be bad actuator motors inside those doors. Swapped them out and everything worked good as new. Tedious fix the first time but it's not too hard.
Part on Amazon is about $10.
echoplex301 is offline   Reply With QuoteReply With Quote
Old 02-19-2017, 11:24 PM #14
wemslie97's Avatar
Real Name: Bill
wemslie97's Avatar
Real Name: Bill
It's possible that the actuator motors in the doors not working could wreak havoc with the security system. It's probably best to make sure that all electronics and Mechanicals of the truck all in working order before attempting to diagnose the RS 3200. just looked through my RS3000 manual and there's nothing about resetting. My bad. Only erasing all remotes is covered. my only other suggestion besides taking it to a professional is to erase the remote and reprogram it. I'm sorry I wish I could help more but this one has me pretty stumped. My rs.3000 works great but admittedly it took me a few tries to get the instructions down well enough to perform the task correctly.
Old 02-20-2017, 01:01 AM #15
ambush ambush is offline
ambush will become famous soon enough
Had the same issue on my 2k Limited. Junction box by your foot drivers side left. The box that holds all the fuses. I got one from someone on the board. No problems.
This is a common issue. Just search the boards:
Door lock problem
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
keyless , remote , unlock
99 Factory key fob/alarm locks but won't unlock doors Rocket3004 3rd gen T4Rs 7 02-13-2023 12:15 AM
Door Locks; auto unlock? wvuviv30 4th Gen T4Rs 11 04-14-2020 08:06 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 8 11-25-2013 08:51 PM
Power locks won't unlock (but locking works) abw73 3rd gen T4Rs 5 11-18-2011 05:39 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 2 04-25-2010 12:42 PM
