Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 01-29-2017, 02:23 PM #1
shoota shoota is offline
Member
shoota is on a distinguished road
Member
Brake pedal hard to push down
So this week this problem started and it's intermittent. It feels exactly like when you pump your brakes 4 or 5 times and it gets harder and harder to push the pedal down. Needless to say this a serious safety concern. Everyone I've talked to seems to think it's the master cylinder but from what I've read the mc just goes bad once and for all, not just kinda every once in while like mine. What do you guys think?
__________________
2000 SR5
shoota is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 03:24 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
Elite Member
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Elite Member
Brake booster for starters.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 04:27 PM #3
Member
Member
Quote:
For starters? Is there any way to figure out what the problem is before I start just replacing things?
__________________
2000 SR5
Old 01-29-2017, 04:44 PM #4
Magmotor's Avatar
Magmotor Magmotor is offline
Member
Magmotor is on a distinguished road
Member
Magmotor's Avatar
Quote:
any codes being thrown? here's a list of items to check for Hard Pedal....
http://tacoma.site40.net/4Runner_96-...r/trou/pst.pdf
__________________
'01 SR5 2WD
Magmotor is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 04:47 PM #5
19963.4lsr5 19963.4lsr5 is online now
Elite Member
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
Elite Member
There is a check valve in a grommet in the brake booster that the vacuum hose attaches to. It fails and causes a hard brake pedal and barely adequate brakes
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-29-2017, 05:03 PM #6
catrains catrains is offline
Senior Member
catrains will become famous soon enough catrains will become famous soon enough
Senior Member
bad master pedal to floor
bad booster high hard pedal.
17 yrs old my guess is booster leak.. when you shut off engine [no vacuum] if the booster is good the brakes should work normally 2-3 times then hard pedal.
the check valve holds vacuum in the booster so when engine dies you still have some braking. if the valve fails this will not cause you problem.
the booster has a rubber part that over time will leak. usually 200K miles and 10-15yrs ...
very easy to check with a vacuum gauge.
catrains is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 05:15 PM #7
alumarine alumarine is offline
Member
alumarine has a spectacular aura about alumarine has a spectacular aura about
Member
Quote:
I don't know about Florida, but a bad check valve can cause a hard brake pedal in colder climates.
__________________
2000 4runner 4wd Auto V6 - Tru-Cool LPD4454 trans cooler in series
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 05:18 PM #8
Elite Member
Elite Member
When the check valve sticks closed it prevents vacuum from going into the brake booster. And the exact explanation of hard pedal etc happened when my check valve failed. And it was intermittent. And really didn't like cold weather. But once it opened after pushing brakes a few times the brakes were fine till it sat overnight.
Old 01-29-2017, 05:52 PM #9
Elite Member
Elite Member
FYI:
https://www.yourmechanic.com/article...-brake-booster
Old 01-29-2017, 08:32 PM #10
Senior Member
Senior Member
Quote:
I never seen one plugged up usually they stay open /leak down .but a check valve plugged up would do it.
could also be booster guts plugged it up .. then need both or just blow out the check valve.
Old 01-29-2017, 08:56 PM #11
Elite Member
Elite Member
Trust me. I tried everything before replacing it. I got lucky and my wrecked 96 parts truck had one that I robbed to get my wife back on the road. A new one was around 50 dollars.
Spraying it with brake cleaner and blowing it out and then shooting a little spray lube had me thinking I fixed it. Then a few days later it happened again in the morning. (She almost hit the tree at the garage) So I just took the one out of the 96. Sadly the bad one only had 125,000 miles on it and the 96 had 230k miles and sat for a year. But, problem never came back after changing it to this day. It's been 2 years now.
A few threads here pointed to the check valve and that info pointed me in the right direction.
Old 01-29-2017, 11:09 PM #12
Member
Member
Thanks everybody.
So clearly living in Florida this isn't a check valve issue related to freezing cold temps, but how likely is it that it could still be the problem part? Either way for under $50 I guess it's worth a try.
__________________
2000 SR5
Old 01-29-2017, 11:17 PM #13
Elite Member
Elite Member
Do you have a friend with a 4Runner? Borrow his.
Old 01-29-2017, 11:23 PM #14
Member
Member
Ok just tried this with my truck that's been off for about eight hours. First couple brake pumps were normal and the third was hard. So that means the brake booster is ok and the check valve is ok too?? Sorry, kinda confused by how you worded it. Thanks
__________________
2000 SR5
Old 01-29-2017, 11:24 PM #15
Member
Member
I do actually. The problem is that this is so infrequent (maybe once a day) that I'm not sure how long I could borrow it to make sure that it's the problem. But I will ask him, good idea.
__________________
2000 SR5
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Strange brake issue - hard pedal Renton4runner 3rd gen T4Rs 22 11-15-2019 04:11 PM
2005 4runner brakes hard to push tecate1987 Maintenance/Detailing 1 07-14-2016 04:59 PM
Towing - how hard can I push the drive train? Crank_It_Up 4th Gen T4Rs 10 05-08-2015 10:00 PM
Brake pedal hard to push? jarnld Classic T4Rs 5 05-14-2008 12:59 PM
How hard can I push my 4Runner independent70 4th Gen T4Rs 10 06-28-2005 02:16 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
