01-31-2017, 06:53 PM
Prevent theft
Do any of you guys have a second or third switch in your car that needs to be engaged/pushed to start your truck?
I have seen quite a few stolen rigs and am considering wiring up something off of the fuel or ignition that needs to be separately engaged to start the vehicle.. Thoughts?
01-31-2017, 07:17 PM
IMO, it's not a great idea to share this kind of information on forums.
01-31-2017, 07:25 PM
I don't do anything beyond the factory anti-theft items (alarm, ignition and window VIN etching and locking it) but you could put an ignition kill switch and hide the switch well. Luck and enjoy the runner.
01-31-2017, 07:35 PM
Real Name: Scott
Real Name: Scott
Is it "easy" to steal without the transponder key? I don't know much about the factory system.
I suppose if someone really wants it they're gonna find a way but I'm mainly curious as to how much of a deterrent the transponder ignition system is. I have the factory system as well.
K82 2000 Limited T4R 4WD V6 auto, factory e-locker, BFG KO2s, Bilstein 5100's all around + 99 talls.
01-31-2017, 10:34 PM
What's nice about most* limited models is that they require a transponder or chip key to get the ignition to turn over..... I had a key cut & had them program the chip key, but they didn't program it correctly so it never turned over. I later programmed the key myself with an existing transponder key & got it work.
Otherwise IMO, a good way to deter theft is not to have items easily seen from the windows.. the entire car is a different story & I know a guy that ALWAYS would put a wheel lock when he parked his truck... but I'm just not that paranoid. But maybe a better insurance policy is the answer or the ticket to a better nights sleep... or visit sleep train. IDK
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
01-31-2017, 10:42 PM
Real Name: Scott
Real Name: Scott
Yeah I think the factory system is fine for my needs. I'm pretty good about making sure I don't leave valuables in the car, and at the very least not in plain sight.
Thanks for the reply!
01-31-2017, 11:34 PM
Install a switch between the ignition and starter solenoid.
02-01-2017, 12:53 AM
Real Name: Levi
Real Name: Levi
Do any of you guys have a second or third switch in your car that needs to be engaged/pushed to start your truck .
Yes . It's something called a clutch . Most people don't know how to operate one anymore .
96 SR5 5 speed, 4:88s with rear ARB , 255/85/R16s , some armor and lights
02-01-2017, 01:12 AM
I have a fuel pump kill switch.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
02-01-2017, 02:00 AM
I saw a guy with a 1st gen 4Runner weld tabs onto his shifters. When parked he'd shift into 4LO/Reverse and padlock them together.
02-01-2017, 03:04 AM
Real Name: Woody
Real Name: Woody
"Variety is for your mind, not your body " —OS
02-01-2017, 03:07 AM
This subject has been discussed at length in various threads.
Truth is, if someone really wants your vehicle -- they will tow the goddamn thing away in broad daylight.
02-01-2017, 12:02 PM
Real Name: Blake
Real Name: Blake
Maybe it's just me, but I feel like people just don't lock their doors like they're supposed to because they never expect it to happen to them. So just lock your doors and don't leave valuables visible in the car.
1996 Toyota 4runner Limited 4wd
Desert Dune Metallic
02-01-2017, 01:23 PM
Real Name: C8H18 Mike
*looking into the Trunk Monkey
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
02-01-2017, 01:33 PM
Real Name: Scramble
Real Name: Scramble
I had the Lo-Jack Anti Theft system installed at the dealer when new. It was expensive but the cost was added into my monthly payments. It has alarm, vehicle recovery & starter disabler. I felt it was necessary parking on the street & living in Brentwood, Long Island. I also used the truck "Club". I dont use the Club anymore now that I live in a rural area but I always lock & engage the alarm when I park.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
