Originally Posted by etc.
Helps the TB from icing up.
Keep in mind the TB can freeze up at temps above freezing. The air passing through the throttle body in a near-closed position goes to very low pressure, thus lowering temps. Lower temps + possible moisture in the air can freeze up the throttle body.
I've never had a problem with it (bypassed on multiple cars that I have driven in temps below freezing) but it is technically possible. I left it in place on my 4Runner though... not really looking for 'more power' from little things like that on the 5vz.
The other line off the throttle body goes to the 'air assist' for the fuel injectors. See this thread for diagrams:
How to Disable Injector Air Assist
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
