05-22-2018, 05:51 PM
#31
Regarding the Irwin Power-Grips: I just remembered that when I used them, I had to use a hammer to get the "spiral flutes" to bite into the smooth surface of the bolt head. The metal was hard and just pushing with the tool in the impact driver wasn't enough for it to grab. Once a little pounding with the hammer created a few notches in the metal, the impact driver easily locked onto those and pulled the bolt right out.
05-22-2018, 09:52 PM
#32
Real Name: Justin
Real Name: Justin
Oddly enough I ended up using a Bolt from 2006 Highlander skid plate to replace mine with just happened to have box full of them
06-10-2018, 11:02 PM
#33
Location: Atlanta, GA, USA, Earth, Sol, Milky Way, Local Group, Known Universe
Specs
Originally Posted by sidusnare
Anyone have the spec on what these screws are, I'm getting mine out and they aren't coming out in a condition I'd want to reuse them.
If anyone else finds this thread looking for the bolt specs, they are:
Diameter: M6
Thread Size: 1.0
Length: 20mm
I am replacing mine with Hex heads instead of the JIS-driver phillips they had in there. I'm not sure the locktite is necessary, I'm going to go without it for now, if it's a problem I can add it later.
____________
'98 4runner 3.4l 4x4 manual
02-05-2019, 11:31 AM
#34
I know this thread is a few months old, but I wanted to chime in with just a less learned. IF the reason to remove these trim pieces is for getting the headliner off and on it is possible to do that while leaving the A pillar trim in place. I've done it on two different 3rd gens, and it is actually possible to remove / reinstall the headliner with the trim still in place. In fact it helps with the headliner reinstall if you're flying solo because the trim will provide a second set of hands for the forward portion of the headliner until you can get the clips back in place in the rear.
If you need to remove the trim pieces for some other purpose, than disregard my post
SO! At last we meet for the first time, for the last time!
10-24-2020, 12:37 AM
#35
Damn I hate these stupid bolts! I made the mistake of trying to use an impact on these and have now rounded the head. There isn't much room in there to torch it with heat. Would love to hear more tips of what you guys have tried to get this out after stripping the head!
10-24-2020, 02:28 AM
#36
Location: Stationed in Camp LeJeune, home is Conover, NC
1/8” drill bit and an easy out.
If you’ve only stripped all the heads; get a JIS bit.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
10-24-2020, 10:55 AM
#37
Real Name: Mark
Real Name: Mark
@nobb, I used a 1/4" drill bit to drill through head of screw separating head from threaded part of screw. Once handle is out of way you can grab what's left with vice grips. JIS bit or screwdriver makes life easy on these.
10-24-2020, 01:02 PM
#38
Real Name: Jerod
Real Name: Jerod
I took a dremel and made a long slice across the head. I then put the biggest flathead screwdriver I had in the groove and it came out.
10-26-2020, 09:32 AM
#40
Real Name: Patrick
Real Name: Patrick
Originally Posted by brillo_76
I use JIS screw driver bits in my mini battery impact driver. They spin right out. I also have JIS screw driver as well..
I didn't know they made JIS driver bits! Do you remember where you got them?
10-26-2020, 12:28 PM
#42
I'll have to wait for Santa to get these for me.
My tool budget
10-26-2020, 12:31 PM
#43
Check it out, McMaster-Carr has loose JIS bits for like $2.
McMaster-Carr
