Originally Posted by TheDurk
This is almost certainly the steel coolant lines to the rear heater. You can quick solve the problem by looping the connection on the firewall and lose your rear heat. Paying someone to replace with Toyota steel lines is quite expensive. It can be relatively easily fixed DIY with generic coolant hose from any auto parts store by sawing out the rusted pieces and fixing in place with screw clamps.
that is exactly what it is
I want to keep the rear heat because my 7-year-old sits back there
The 4runner is now in the south and will not be exposed to snow/salt roads often, if ever
when you say generic coolant hose would that be the rubber hose instead of metal line?
