02-16-2017, 11:06 AM
Runner won't start, relay makes noise but no start
Hello all, I need expert help. I can turn my Key and only hear a relay making noise but no start, starter is good. 99 3.4 auto. Please help
It means no worries
98.75 auto sr5 4 runner, 99 limited motor, trans. And rear end. Limited interior, bilsteins in all 4 corners Toltec 3in. Spring, 891 coils... dd project
02-16-2017, 11:07 AM
wack the starter see what happens? lol what is battery voltage?
2004 limited V8
2002 SR5 V6
02-16-2017, 11:14 AM
Are you sure you're getting fuel? Loosen nut of fuel filter and have a buddy start car. Just watch your eyes .
02-16-2017, 11:15 AM
You pulled starter and tested it? Like stated what's battery voltage at standby and during crank?
02-16-2017, 11:16 AM
He said it just clicks. Not cranking. So fuel is not the issue.
02-16-2017, 11:23 AM
Quick shade tree voltage test - turn the dome light on and watch it while you try to crank. If it clicks and the light really doesn't dim much, it's not the battery. If it clicks and the light dims, the battery is weak.
A multimeter is better to put some numbers to it. But I'm with JayRolla - how do you know the starter is good? It's not uncommon for contacts in the starter to go bad, and when they do the symptoms are that it will click click click click crank.
02-16-2017, 11:25 AM
Real Name: Trav
Real Name: Trav
check voltage and check starter solenoid. sometimes tapping the solenoid works and it will start.
02-16-2017, 11:40 AM
Real Name: Matthew
Real Name: Matthew
Check all your grounds and connections. Sounds stupid but something being lose could definitely be the problem if the starter relay is clicking
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
02-16-2017, 03:18 PM
My brand new Nippon starter did that the first day of use. Exchanged it for another no problems with second one.
02-16-2017, 04:14 PM
Ive had no start/no crank issues from poor battery terminal connections before.
Check to see if they are tight. I have had my truck not start and they seemed tight. I removed the terminals and reconnected and all was fine.
Sometimes its really simple things that can help
1997 4Runner 5 Speed E-Locker
02-16-2017, 04:58 PM
I just had bad starter contacts and got the same symptoms. Will it crank after several tries?
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
02-16-2017, 05:03 PM
BUY NEW TRUCK That will fix it.
02-16-2017, 06:08 PM
Just had the starter tested this morning and it hit just fine at advance. Can't find and bad grounds....
It means no worries
02-16-2017, 06:18 PM
I've had this happen several times in the past. It was always one of 3 things.
Dead battery.
Loose or corroded battery terminal connections
Bad starter contacts.
At one point, I had all 3 issues and it was a pain in the ass.
Have you tried jump starting?
02-16-2017, 06:59 PM
Starter solenoid wire doesn't have power any suggestions?
It means no worries
