Old 02-24-2017, 11:03 AM #1
4runnerWiniarski23 4runnerWiniarski23 is offline
Real Name: Al
4runnerWiniarski23 is on a distinguished road
Real Name: Al
Rear Diff Leak
Hi guys,
I was under my truck the other day and I noticed my rear diff has been leaking slowly. I noticed it looks to be leaking at the breather. I recently had a East Coast Gear diff installed so I do not believe its the pinion seal.Fluid running down from the breather to the bottom and then throwing it back.
Is it possible that the breather seal is leaking? Warmer weather causing the fluid to be pushed up out of the breather? Is the breather an NPT thread that maybe needs some Teflon?
Also recently getting P0440 and P0446 after changing plugs. Gotta do some more research on where to start with these. Could be a evap hose pluged or disconnected? Gas gap?
Thanks in advance.
Alex W.
4runnerWiniarski23 is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 12:05 PM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Fluid should not come out the breather.
Did you check the fluid level?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 12:09 PM #3
Real Name: Al
Real Name: Al
I did check the fluid level because I was concerned it was low. I removed the fill plug, no fluid came out. I continued to add fluid until a little fluid dripped out out, replaced fill plug.
Breather sticks out the top of the axle housing, so am I wrong to think that in order to over fill it enough for it to come out of the breather it would be difficult considering the fill plug is much lower.
Old 02-24-2017, 12:15 PM #4
Real Name: Al
Real Name: Al
Im pretty certain it is the breather, lunch time coming up I will snap a picture and upload so you guys can confirm it.
Old 02-24-2017, 12:18 PM #5
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
I believe the correct fill is just below the fill hole about 1/4"
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 12:38 PM #6
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
If it was the pinion seal, you'd see oil slung all over the place since it's a rotating part. That should rule that out pretty quick. I would get the breather replaced asap because all that pressure not escaping could cause your axle seals to leak, and then you'll have bigger fish to fry.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 12:42 PM #7
Real Name: Al
Real Name: Al
Agreed on ruling out the pinion seal.
Breather is cheap enough I will get that this weekend.
If the fluid is high then I can see it being pushed elsewhere instead of out of the breather and there is zero fluid at my wheels or anywhere else for that matter.
Old 02-24-2017, 01:41 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The correct level is right at the bottom of the threads of the fill plug but the FSM says if it's within 5mm of the bottom of the fill plug threads then it's OK. Nobody is going to try to fill exactly to 5mm or 1/4" from the lip. When you fill a differential, transfer case or manual transmission, you fill until you see gear oil spilling out and then you're good. This is auto mechanics 101.
If you're getting gear oil out the breather it's because you either overfilled because you filled the diff while it was at a slant downward towards the front of the rig or the breather is sticking and the pressure is building higher than normal and when the pressure finally overcomes the sticking breather oil is joining the air escaping.
Old 02-24-2017, 01:53 PM #9
Real Name: Al
Real Name: Al
So i went and tried to grab a picture of the leakage at lunch time. The picture is tough but you can see the fluid has been running from the breather down the left of the pumpkin for some time.
I removed the breather and cleaned it out. It is moving freely without hesitation, I even blew some air and feel it coming out. still not ruling out the fact that the internals could have an issue.
I decieded to add some teflon tape to the threads to help prevent any leaks. If the diff is overfilled it will continue to leak until its at a happy level. I will monitor it.
Rear Diff Leak-20170224_124647-1-jpg  Rear Diff Leak-20170224_122254-jpg
Old 02-24-2017, 02:31 PM #10
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Some lighter weight / synthetics will do this as well.
SaulG is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 02:51 PM #11
Real Name: Al
Real Name: Al
Saul, you could be on to this. I did put in a synthetic fluid when topping it off the other day, going to pick up some reg GL5 this weekend.
Old 02-24-2017, 04:09 PM #12
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
the gear oil used is not the problem the breather threads are the problem . you can't over fill ....... you fill to the bottom of fill plug.
if it still leaks at around the breather then you buy new breather. could be they cracked it.
catrains is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 09:00 AM #13
Real Name: Al
Real Name: Al
Does anyone have the part# for the OEM plug? or is doing the diff extender really the only option.
I plan on taking the truck some 800 miles this weekend and would like have this solved. My plan is to get a new plug or extender and add some fluid. The leak should stop then. I agree the threads could be the culprit.
Old 02-28-2017, 10:45 AM #14
johnbyebye johnbyebye is offline
Real Name: Scott
johnbyebye is on a distinguished road
Real Name: Scott
I just replaced mine as well. 90930-03031
K82 2000 Limited T4R 4WD V6 auto, factory e-locker, BFG KO2s, Bilstein 5100's all around + 99 talls.
johnbyebye is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 11:58 AM #15
Real Name: Al
Real Name: Al
Thank you very much !
Rear Diff Leak PWD4R General Discussions 11 08-16-2016 03:16 PM
Rear Diff Leak PWD4R 3rd gen T4Rs 6 08-12-2016 10:48 PM
Rear diff leak 99ToyoRunner 3rd gen T4Rs 14 04-14-2014 09:09 AM
Rear diff leak? mtpktz. 3rd gen T4Rs 10 11-27-2011 07:42 PM
Rear Diff leak... Nelsonmd 3rd gen T4Rs 15 05-31-2011 02:19 AM
