Old 03-26-2017, 12:10 PM #1
Miyota's Avatar
Miyota Miyota is offline
Real Name: evan
Miyota is on a distinguished road
Miyota's Avatar
Real Name: evan
3rd gen alignment specs. What to go with?
Alright, I need a little help from everyone here. My 2000 limited is having issues with driving poorly and the upper ball joints are binding. It has been lifted for only a year, up front I have toytec coils on Bilstein 5100's set in the middle slot and out back I have toytec superflex coils and 5100's. I did use the 1" differential drop kit up front and put a pan hard drop bracket out back. So I have decided to upgrade the upper control arms all together with the following to correct the ball joints that are binding and give me more flexibility with alignment.
25460 - SPC Upper Control Arms for 95.5-04 Tacoma and 96-02 4Runner
Now I know some of you out there will be asking why not uniball? Well up hear in the Northeast the salt in the winter time is un-earthly and ruins things quite quickly. So this option will give me better camber and caster adjustment and it's sealed off from the road salt.
My question to all of you out there with 3" of lift is how far out from the original alignment specs should I go with all of this. Driving my truck at 65 down the turnpike it floats all over the road and even in town the steering wheel only returns to center with help. Any help is greatly appreciated.
Sent from my Pixel XL using Tapatalk
Miyota is offline   Reply With QuoteReply With Quote
Old 03-26-2017, 12:26 PM #2
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Keep the alignment within the factory specs. I went with less caster with my SPC uppers to clear my 35s. I only did this because it did not compromise the handling compared to when I had my alignment in the factory range.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 03-26-2017, 12:29 PM #3
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
What size tires are you running?
JayRolla is offline   Reply With QuoteReply With Quote
Old 03-26-2017, 03:33 PM #4
Miyota's Avatar
Real Name: evan
Miyota's Avatar
Real Name: evan
I am running 285s. I just want it to handle like factory even with the lift. Do you think the fact that it doesn't return to center is from the ball joints binding?
Old 03-26-2017, 11:31 PM #5
Junkwhale Junkwhale is offline
Junkwhale is on a distinguished road
What can actually be adjusted in terms of alignment on 3rd gens? I'm pretty new to them and haven't actually had a chance to get mine off the ground and look at the suspension.
For the fronts (double a-arms?) I'm assuming camber / caster via eccentrics, and toe?
What about the solid rear? Is it just toe? (if even that?)
Junkwhale is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 06:50 AM #6
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
The reason it's having the issues your describing is because of the loss of caster with the lift. I'll bet you have near zero caster when factory spec is between 1.7 to 3.4 degrees with no more than .5 difference left to right. It's a slippery slope with caster. Too much and the wheel makes contact with the front of the fender or the flares, too little and you'll hit the rear of the wheel well. Surprised you're not rubbing on the rear well right now.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 09:39 AM #7
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Of course we can only give you a theoretical answer here, I've never seen ball joints bind. The two angles that create self centering steering are Caster and Steering Axis Incliniation(SAI). They are both the same line drawn between the upper and lower ball joints. Caster is measured as viewed from the side of the vehicle, and SAI is measured as viewed from the front of the vehicle.
Generally the lift pushes the suspension down so the angles change, in a negative way. The Caster becomes less positive, and so does the SAI. Aftermarket upper arms help to correct these angles by placing the ball joint slightly rearward(positive caster) and inboard(positive SAI).
It would be good if you had alignment readings as a baseline, so you could know where you might end up with the new arms.
Here is some further explanation.
Circles and Arrows
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 09:43 AM #8
No rear adjustment on a solid axle. The front uses a long arm short arm set up with eccentrics on the lower arms. This allows both camber and caster adjustments. Haven't seen a vehicle without toe adjustment on the steering axle.
Old 03-27-2017, 09:44 AM #9
Miyota's Avatar
Real Name: evan
Miyota's Avatar
Real Name: evan
I had to trim my fender flares front and rear for the tires to clear and the tire rubs on the rear of the frame when it's at full turn.
Old 03-27-2017, 10:03 AM #10
Miyota's Avatar
Real Name: evan
Miyota's Avatar
Real Name: evan
Circles and Arrows
Thank you for sending that and giving me that explanation. I can't find my print out from my last alignment. I know it was within specs and I think because they got is so close to factory with the amount of lift that is why I am having a binding problem. I found a post on TORRA that had to do with 3" spacer lifts (I don't have a spacer lift but I have 3" of lift) and I said if you have that much lift there is a good chance of your upper ball joints binding.
http://www.ttora.com/forum/showthread.php?t=110876
Old 03-27-2017, 02:16 PM #11
The binding comes form excessive lift from a spacer that allows excessive droop (top spacer above from coilover). The binding happens at full droop, not at ride height.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
How do my alignment specs looks? Stillbreathn 5th gen T4Rs 9 08-18-2015 09:29 PM
I know nothing about alignment specs! TJQ 4th Gen T4Rs 6 07-07-2014 10:17 AM
How do my alignment specs look? hec983 5th gen T4Rs 16 10-08-2012 02:28 PM
Alignment Specs? 4RBob 5th gen T4Rs 10 05-27-2010 07:38 PM
Anyone have the specs for alignment on a 4th gen? G.I.G. 4th Gen T4Rs 1 01-19-2009 07:22 PM
