Have you considered an FJ Cruiser MT transfer case instead? Full-time 4WD with torsen AWD, 4WD (locked) and 4L all mechanically controlled. Most of the 'modern' Toyota transfer cases have the same mounting bolt pattern, so they should all bolt up to the transfer case adapter on the back of your (auto?) transmission. Driveshaft lengths will be different depending on which case you get. Any of them with electrical control will be harder to put in unless all the wiring component matches your current 4WD computer.
If it does all work, report back... I have a plan brewing along these lines but it will be a year or two until I can get to that project.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
