04-08-2021, 01:40 PM
#196
5vz fe engine cover gasket leaking
To: ramonortiz55, Appreciate your Craftsmanship very much! Just would like to know how your vehicle performs later. Thank you
04-12-2021, 10:23 PM
#197
Real Name: Devan
Real Name: Devan
Gonna be tackling mine again sometime soon, and was curious if anybody here has tried this kit from partsgeek? They say it's supposedly OEM but the price is much cheaper than if you were to put it altogether from somewhere like toyotapartsdeal. I've never used partsgeek before, always seemed kinda sketchy to me, so I was hoping to hear someone chime in
04-13-2021, 01:07 PM
#198
Real Name: 3 Bears
Real Name: 3 Bears
I can not speak to that set....but if oem that is a very good price. Let us know as I need to do timing belt and vc gaskets .
on the other hand....many years back I got a set of Ishino valve cover gaskets, they were advetised as OEM....and said, orignlal supplier to toyota . They fit perfecct and I never had a problem with them. I have looked and and cant find the Ishino again for our engines.
I wonder if at that price point ( the ones you are looking at) if they are something like that. Nothing wrong with that , we know many suppliers are suppliers to Toyota and we can get the same parts....like seals and stuff....cheaper but same company/supplier to toyota. Cabinmans ( ebay) timing belt kits come to mind on that. He sells a DNJ kit valve cover kit for about 70. Most of what he sells is original supplier. and seems he has a pretty good reputation on this forum and other forums for toyota stuff.
05-26-2021, 09:03 PM
#199
Would it be a good idea to go ahead and break the wire loom plastic above the driver side valve cover prematurely and wrap in high temp tape to prevent any pieces from going into the valve train?
2001 SR5 4WD
05-26-2021, 10:15 PM
#200
Real Name: Devan
Real Name: Devan
I recommend removing it before you take the valve covers off and replace it all with some corrugated plastic tubing. It's flexible, dirt cheap, it'll stand up to the temps just fine and it looks much cleaner than wrapping with tape. You have the right idea, there's no real sense in keeping it since it's practically a hazard with how brittle they are. A piece is begging to come off and go down the intake so much sure to block that off too
05-27-2021, 05:19 PM
#201
What diameter do you recommend for the wiring loom? I will make sure to get a high temperature stuff
2001 SR5 4WD
05-27-2021, 07:39 PM
#202
Real Name: Devan
Real Name: Devan
Not sure, I just grabbed some stuff laying in my garage. Probably around 1.25" would be my guess but it's been a while
09-18-2021, 10:43 PM
#203
Excellent description! Question: how do you keep track of all the bolts, nuts and studs without labelling?
09-18-2021, 11:07 PM
#204
Real Name: Tim
Real Name: Tim
It's best to bag and label your fasteners as you go. This takes the guesswork out of it when it's time to put things back together.
03-25-2022, 09:16 PM
#205
Real Name: Roman Schnobrich
Awesome and helpful write up! Add me to the list of thankful guys still using this all these years later. We all owe you beers some day!
2000 SR5 Midtravel Cookie Cutter Build
https://www.instagram.com/roamin.creative/
03-28-2022, 12:25 PM
#206
Real Name: C8H18 Mike
I will be tackling this on my 4WD soon and will report any updates "tips or tricks" as I'm adding an injector swapgrade to the menu
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
11-29-2022, 01:44 PM
#207
You're a lifesaver! Thank you so much!
01-08-2023, 11:08 PM
#208
question
Hey man,
Can I ask - did you do the FRONT camshaft plugs as well? Or just the rear ones? The one one the front passenger side seems impossible to get out (due to clearance from the radiator mount in front of it). Just curious if you did the front ones as well, and if you didn't - was it for the same reason, or some other reason?
Anyone here have a response? Thanks!
05-13-2024, 04:36 PM
#209
A year or more ago with the help of this write up and the FSM, I replaced the valve cover gaskets. I struggled with the driver side, and based on someone else's write-up I didn't bother replacing the camshaft plug on the left side.
Yep. it was leaking.
I went back today and re-did the left side. Took about five hours. Crossing my fingers this takes care of things.
I'll go back one day and replace some hard as rock, cracked hoses. None of those seem to cause issues.
This has proven a great resource!
1999 Ltd 4x4
