Awesome write-up
ramonortiz55
, I just finished this project this past Friday. A few tips for people who decide to do this:
-The plastic covers for the wire harness that runs over both sides are very brittle. Make sure you remove them before you take the valve covers off so pieces don't fall in. No matter how careful you are, parts will break off.
-I used Extreme Tape to wrap the wires. This silicone wrap is rated up to 500 degrees, that is plenty of protection from the heat. If you've never heard of Extreme Tape, just Google it and you will find plenty of info on it.
-With the plastic wire harness covers removed, your ability to remove and install the driver's side valve cover makes it a breeze. It's pretty amazing how much room you gain from removing that "restrictive" plastic cover.
-Silicone lube spray is your friend! Silicone is safe for plastic and rubber, petroleum based products are not. By just dabbing a little silicone spray on rubber seals helps seat them. This came in really handy for the spark plug tube seals. I didn't even have to bend up the tabs to remove the old ones and install the new ones.
