04-12-2017, 01:52 AM
Brakes...worth the Tundra upgrade?
My brakes are on the way out. Either gonna get new pads (less $$$) or do the Tundra upgrade (more $$$). Just curious since it is popular, do I absolutely HAVE to go up to the 231s? I have the stock 5 spoke 16" rims so they'll fit according to Big Fish All Day's page on this.
I was looking at RockAuto today and they have the full Tundra kit for $270. This is the Power Stop Z23 kit with rotors, calipers, pads, etc.
Anyone hear good things about these vs OEM?
04-12-2017, 01:55 AM
Real Name: Bobby Barnhouse
You can junk yard it all, rebuild the calipers super easy and cheap like 15 bucks for rebuild kit, I paid 12 bucks for both calipers a few months back, then I found rotors at different junk yard that were really nice, had them re turned at Napa and I think I'm into my TBU for under 60 bucks total....including brake fluid and paper towels haha
'97 3rz. Bilstein 5100/Toytec front coilover kit. Rear Bilstein 5100 extended travel/Toytec super flex coils springs. Powder coated sequoia 17's wrapped in lt255/75 bfg mt's. Diff drop..
04-12-2017, 02:09 AM
Another thing I wanted to know was whether the tundra 199s are better than the stock 4runner. In the rare event I need to change a tire, I don't want the spare tire to not fit over the 231s. I read that the stock spares are smaller rims. I don't actually know if my spare is stock though..
04-12-2017, 02:51 AM
I'm gonna say the 199's are better, as far as stopping, less warping than t4r stock, I never thought about the whole spare tire situation, but you could always move a rear tire/wheel to the front and run the spare in the rear in the event that you do get a front flat. Maybe others with more knowledge on the 199's pro's/con's will chime in tomorrow, I'm not an expert by any means but hope it helps ya! Lol
04-12-2017, 02:52 AM
I'm pretty sure my steel spare won't fit the tundra calipers. I'm considering putting a spare matching wheel underneath as the spare.
These are my wheels and I have the calipers high spot ground down to clear these wheels with no modification or grinding on the wheel.
04-12-2017, 04:52 AM
Real Name: Alex
Real Name: Alex
231s
yes and yes, the best upgrade on a 3rd gen.
go find a spare from a limited or go find a limited rim 6 spoke i think.
04-12-2017, 08:31 AM
x2 ^^^^^ BEST "mod" you'll ever do coupled with SS brake lines.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
04-12-2017, 08:45 AM
You can toss a wheel spacer in the back just incase you want to change to the spare, but i call AAA even tho i have a truck full of tools. I ground a bit on the stock wheels. Fits my 231upgrade just fine. Just plan to adjust the rear brakes too
04-12-2017, 09:21 AM
I'm going to go against the grain and say if you don't tow a trailer, or have oversized tires, then there's no reason to change to Tundra brakes.
Curious if any of the folks who recommend this are running stock tire size. I run 265/75 and occasionally tow a light tent trailer or utility trailer (<2500 lb) and I've never had an issue with the stock braking system.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
04-12-2017, 09:42 AM
If I had not used my 4runner to tow my boats for two summers then I would not have put the Tundra brakes on.
If you tow and/or do a good bit of off road exploring, then by all means.
04-12-2017, 09:58 AM
I'm gonna go out on a limb here and say, YES. But that might be because I have the Powerstop Kit sitting on my garage floor waiting for me to install it. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
04-12-2017, 10:49 AM
Yes it's worth it. Yes 5 spoke wheels fit over them.
04-12-2017, 10:55 AM
Same here. My rig's got no armour and I never tow. So aside from 285/75R16 tires, it's pretty much basic duty with my T4R. I also have the Limited which does have the slightly larger brakes to begin with. I never felt the need to do the TBU.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
04-12-2017, 11:25 AM
I did the power stop TBU and was very impressed minus some noises and the dust
If you upsize tires, especially to an e load, this is a crucial upgrade
04-12-2017, 12:41 PM
Real Name: Jerod
Real Name: Jerod
I bought some simple 1/4" wheel spacers for this situation, it's enough to clear the calipers with them on. But just moving the tires around works too.
Yup, stock tires size here.
I don't don't tow either but did it because I was having trouble stopping on hills or highways situations when I needed to stop very fast. Had a few times when ABS would kick in too.
The Tundra brake upgrade greatly improved my stopping distance. New tires a few years later took care of my ABS issues.
