Actually, no. the multi-mode TCs also make use of GL5 gear oil, not ATF.
I think you're referring to the 2nd gen 4Runner TC that uses ATF (TCs attached to automatic trannies.
Originally Posted by Alabamaguy
The multi mode uses a common fluid with the transmission (atf) while the conventional (non-limited model) case uses gear oil and is sealed from the transmission. That's the limit of my understanding at least.
