Old 04-26-2017, 04:14 PM #1
Rendell's Avatar
Rendell Rendell is offline
Rendell is on a distinguished road
Rendell's Avatar
Toyota Supra twin turbo 2JZGTE Engine 2JZGTE Engine swap?
Anyone tried it? Success, failure.. Just checking. I'm looking for more power from my 97 limited..
97 Limited 4Runner Dessert Dune Limited.
Rendell is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 04:25 PM #2
LIVEVIL LIVEVIL is offline
LIVEVIL is on a distinguished road
Let us know how that works out for you.....
Maybe you can overnight parts from Japan
LIVEVIL is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 04:26 PM #3
Atomic6's Avatar
Atomic6 Atomic6 is offline
Real Name: Tim
Atomic6 will become famous soon enough
Atomic6's Avatar
Real Name: Tim
I know it's been done with a Tacoma and the engine bay is pretty much identical to a 4Runner.
2JZGTE Swap Into A 1998 4x4 V6 5 Speed Tacoma by mmccul3797 | Photobucket
Also, search... This comes up from time to time and you'll get the same answer every time.
could it, should it be done?
2JZ into a 3rd gen
2nd gen swap:
Project: SupraRunner 2jzgte swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Atomic6 is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 04:27 PM #4
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
I don't think you could have thought of a more difficult and absurdly expensive engine swap. Other than a Ferrari or Lamborghini engine instead of a 2J
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 04:39 PM #5
Rendell's Avatar
Rendell's Avatar
Could you elaborate/quantify your opinion? I'm just wondering why it is so wrong... The HP is nearly double to the 3.4L V6.. It's a toyota engine. It shouldn't cost much more than adding a supercharger, and not gaining more than 20 to 30 HP, on a great cool temp day..
Old 04-26-2017, 04:42 PM #6
I'mStock I'mStock is offline
I'mStock is on a distinguished road
You wish.
-Tyler
Instagram -TF_Tyler
'98 LTD | Misguided and poorly planned
I'mStock is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 04:47 PM #7
Rendell's Avatar
Rendell's Avatar
alright negative Nellies, why just dog the idea without adding some back up? A person has to ask the questions, before they jump in.
Why is it so wrong?
How do you know it's so expensive? Did you try it, spend a crapload, and then just want to dog someone else because you learned the hard way?
bring up some factual information instead of opinions..
Old 04-26-2017, 05:10 PM #8
Why is it so wrong?
Engine swaps have been discussed a million times and the same issues factor in to all of them; Custom mounting, transmission interchangeability, custom cooling (if needed), custom wiring, etc...
Suffice it to say, if you're asking these questions and assuming that the cost of an engine swap will be a wash compared to a TRD SC then you just haven't bothered to research it. Do some research my man, put forth some effort rather than expecting to be spoon fed the information.
-Tyler
Instagram -TF_Tyler
Old 04-26-2017, 05:43 PM #9
meRockboost meRockboost is offline
Real Name: Rock
meRockboost is on a distinguished road
Real Name: Rock
If you won't be doing the welding and fab work then you won't want the bill.
2021 Nightshade (wifey’s). 1998 Limited-locked, lifted, armored, sold. 2015 SR5, stock and sold. 2002 Sport edition, sold.
meRockboost is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 06:03 PM #10
Rendell's Avatar
Rendell's Avatar
You see, That didn't hurt a bit did it? No I haven't. It was an idea that flashed through my mind, and I figured it would be a good discussion. Which is what is happening here in your last post (all but the last part)..
Appreciate your time.
Old 04-26-2017, 06:04 PM #11
Rendell's Avatar
Rendell's Avatar
Absolutely. The fab work would be very costly, if it were hired out.
Old 04-26-2017, 06:07 PM #12
Rendell's Avatar
Rendell's Avatar
2JZ into a 3rd gen
2nd gen swap:
Thank you, I read most of a couple of those, and the fab is extensive. It seems other than that it would be about as difficult as any other swap.. But is doable..the could to should Ratio is where I was looking to get some discussion. Thank you great post.
Old 04-26-2017, 06:20 PM #13
Cadaverous's Avatar
Cadaverous Cadaverous is offline
Cadaverous is on a distinguished road
Cadaverous's Avatar
Well, an s85 would be way more expensive and absurd.
I agree. Asking such basic questions about such complicated things means that not enough time has been spent researching. And if you can't be bothered to research, than you won't be able to do the swap.
Cadaverous is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 06:20 PM #14
Lindenwood's Avatar
Lindenwood Lindenwood is offline
Lindenwood is on a distinguished road
Lindenwood's Avatar
The major issue that come to mind is the extensive length of the I6 vs the V6. Length-wise, a mid-sized V6 like ours is about the same length as, if not still shorter than, most large 4-bangers like the 2.7.
Having not read any of those threads, and honestly not caring to, I would imagine most of the fab work comes from dealing with that obstacle.
Lindenwood is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 06:25 PM #15
idlingmike idlingmike is offline
idlingmike is on a distinguished road
Well, we can start off with the actual engine mounts, how will you have them made unless you know how to weld? (keep in mind at this point your truck is sitting with no engine, and the 2jz dangling by an engine hoist. Will you contract a fabricator to come over to your house? measure everything, then run back and forth between your place and his machine shop?), then what will you use to adapt the 2jz to your transmission? What will you use for a torque converter because the splines are very unlikely to match up. Custom torque converters, not that cheap.
BTW, good luck finding a good used 2jzgte for anywhere near a reasonably price. Enough time has passed that you can't just find a bunch of JDM ones in a warehouse, and everyone from Supra guys, Lexus guys, hell, even Mustangs, 350z's, 240's are putting those into their cars.
Next, it's very unlikely the factory turbo system to exhaust will just line up to the 4runner chassis, cross members, etcso I'll give you a break and just assume an eBay manifold puts the turbocharger in a reasonable enough place and you won't have to have one made, you still need a fabricator to work out all the wastegate recirculation to exhaust plumbing.
Next we have wiring, engine management, tuning. Do you know how to do these things? --And have the speedometer, gauges, warning lights, shifter all work. Do you know how to do all that? Without it being months of work?
Then comes all the trivial stuff, finding the right intercooler to fit behind the stock bumper, fabricating mounts, fabricating intercooler plumbing, the stock ecu will work, but might throw 10 different engine codes including emissions codes, so you'll either have to hunt every single one down or go with an aftermarket engine management system and tune.
Next we can move onto reliability, those one-off wastegate recirculation pipes might not like the bit of flex from those one-off engine mounts or the flex of the factory 4Runner transmission mount, the vast, vast majority of stand alone engine management setups need constant attention. That 20-25 year old engine harness that you found used from that guy on craigslist has now been hacked, cut, extended, etc, runs across hot spots in the engine bay, etc. This also assumes there is absolutely nothing wrong with that used engine, electronics, etc. Good luck getting your money back for them after you've had them for months trying to get it to work in a one-off setup.
Finally, some day, that sweet 2jzgte is going to make some good power, mild setups will make 450-600 crank horsepower. The 4Runner stock transmission probably won't hold that and will blow up. What now? Keep blowing up stock transmissions? Find someone to build a one-off built one? Figure out a way to adapt the Supra transmission to your transfer case? Repeat step one.
So we have...
Good used engine
Custom engine mounts
Engine harness
Intercooler
Custom plumbing
Turbocharger
Wastegate
Blowoff valve
Custom plumbing for all the above
Custom engine to transmission adapter
Stand Alone Engine management
Tuning
Electrical's unless you're really good with these.
Then any frankenstein car, you better be good at troubleshooting and working on stuff on your own. Most shops won't want to touch it.
Why is it so wrong?
idlingmike is offline   Reply With QuoteReply With Quote
Trade? SC300 2JZGTE-V160 - BIG DIFF-KW V3 mikeferg For Sale: Vehicles 7 07-22-2016 01:02 AM
Catt's 98 Toyota Supra Turbo full build process CWebb All Other Vehicles 21 10-28-2015 04:38 PM
Toyota JDM 2L-TE Turbo Diesel Engine-$2199 foyaboya For Sale: T4R Items 0 08-29-2012 02:05 PM
93'-98' Toyota Supra Twin Turbo VS. Nissan Skyline R34 andyman32392 All Other Vehicles 30 08-22-2012 10:31 PM
I'm thinking about a 2.4L Turbo diesel engine swap s2kpuddydad Classic T4Rs 3 10-20-2009 09:47 PM
