Old 04-29-2017, 10:30 AM #1
SRQ-Runner SRQ-Runner is offline
Real Name: Matt
SRQ-Runner will become famous soon enough SRQ-Runner will become famous soon enough
Real Name: Matt
MCM Fab 3.5" Long Travel Kit
MCM Fab 3.5” Long Travel Suspension Kit
This kit is not new to the market. George Otwell ran this kit for a couple years and has nothing but good things to say about it!
Pricing:
Sold here: https://www.srqfabrications.com/prod...vel-suspension
Base kit: $2400 with free shipping
4wd extended CV axles: $560 (modified Tundra axles)
Coilover options:
-8” 2.5 FOA w/ Viper coils (600lb) and resis $575
-8” 2.5 ADS w/ Eibach coils (600lb) and resis $1400
If you'd like a higher or lower spring rate, that is not a problem and can be ordered with the kit. Matt over at MCM Fab has just found that the 600lb springs are the best starting point for most people.
Included in kit:
Powdercoated Satin Black
MIG welded boxed and internally ribbed lower control arms
TIG welded DOM upper control arms with high quality FK Stainless Bearings
Limiting straps
Extended brake lines
Extension for tie rod ends
Kit includes all necessary hardware for install (bushings, sleeves, etc.)
Specifications:
3.5” wider track width per side
13” of wheel travel
4wd compatible
Reuses the stock LBJ
Install:
I’m a full time college student and currently live in an apartment complex about 5 minutes from school. I completed the install over 2 days and 25 hours of work in my apartment parking lot. If that isn’t a testament to how easy and well-designed this kit is, I don’t know what is. No fancy equipment or tools are needed to install this kit. Some 6 ton jacks stands, a hydraulic jack, and your normal tools will get the job done! Here are a few photos I took throughout the tear down and install.
Cutting the stock ball joint to be pressed out
Spindle ready for uniball adapter
The kit just dropped off by UPS
All laid out
Removing all the stock components
I’m sure my apartment complex loves me
The install
The uniball adapter uses the stock UBJ snap ring
Tie rod extensions (included in kit)
FOA coilovers
Driver side nearing completion
Passenger side completed and sitting on the ground. This was before the truck had even moved so not a great representation of current ride height. Don’t mind the zip ties holding the resis up, I have mounts waiting at home for me!
Finished product:
Thoughts so far:
I’ve had the kit for 2 weeks now and couldn’t be happier. Last weekend I drove 500 miles round trip in one day to check out the Yota Mafia meet in Atlanta. Mind you, this was less than a week after finishing the install and I didn’t have a single problem. I’ve only hit the trails once with the kit as I’ve been trying to get a few miles on it before I start testing its limits. Being that the 4runner is my DD, the miles are already racking up quickly. I should have over 1000 miles on the kit by the 2nd week in May. Next weekend I make a 350 miles trip home to visit my parents. While I’m down there I hope to have time to cycle the suspension and get some travel numbers. I also will be ordering hydro bumps, TC spindle gussets, and TC cam gussets. I have the coilovers set as low as I can and the front end still sits slighty higher than the rear. Since I am 2wd 2.7L I don't have much weight up front, with the being said I plan on getting some 500lb springs to swap out for the current 600lb springs. I really hope to dial in the kit over the coming months along with redo my rear end which is in need of a huge upgrade.
SRQ-Runner is offline   Reply With QuoteReply With Quote
Old 04-29-2017, 10:44 AM #2
mountain mike's Avatar
mountain mike mountain mike is offline
mountain mike is on a distinguished road
Bad ass!! Looks awesome.
2001 Black Sport Package
mountain mike is offline   Reply With QuoteReply With Quote
Old 04-29-2017, 02:12 PM #3
Real Name: Matt
Real Name: Matt
"Basically I ran MCM FAB long travel IFS for 4-5 years. I was on the cover of 4wd Toyota owners mag and had a full write up because of the SA rigs I was keeping up with and even out performing at times. I ran 38" super swampers, 529s, ARB'S and duel casses. The heavy duty Tundra axles worked out great for me. I was able to rally & rock crawl. Was really the best of both worlds!"
-George Otwell
A couple shots of George's Tacoma rocking this LT kit.
Old 04-30-2017, 08:01 AM #4
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
Why are there two different mounting points for the lower shock mount on the new lower control arms?
audiness is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 09:00 AM #5
jstim's Avatar
jstim jstim is offline
Real Name: Josh
jstim is on a distinguished road
jstim's Avatar
Real Name: Josh
With long travel, a lot of the hardcore baja types will add a second shock up front. You add the hoop above the uca, and then add the shock to the hoop and second mounting position I believe.
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread:http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper View Post
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
jstim is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 09:36 AM #6
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Looks so nice. But then bolting on the junky ome lbj kind of sucks. Wish those were uniball.
JayRolla is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 11:35 AM #7
Real Name: Matt
Real Name: Matt
The other mount can be used for a second shock or limit straps.
Old 04-30-2017, 12:00 PM #8
Atomic6's Avatar
Atomic6 Atomic6 is offline
Real Name: Tim
Atomic6 will become famous soon enough
Atomic6's Avatar
Real Name: Tim
You forgot to install the front CVs and diff!
Atomic6 is offline   Reply With QuoteReply With Quote
Old 07-30-2017, 09:29 PM #9
Real Name: Matt
Real Name: Matt
Here's a few photos of this kit in action! Around 4,000 miles on the kit and haven't had a single issue.
Old 09-25-2021, 09:50 PM #10
AntonioCm1983's Avatar
AntonioCm1983 AntonioCm1983 is offline
Real Name: Antonio Claudio Michael
AntonioCm1983 is on a distinguished road
Question I'm looking at mcm fab long travel kit and also looking at total chaos fab long travel kit as well I know total chaos don't come with coil overs or tundra CVS or rack spacers.. what is everyone's take on mcm long travel vs total chaos fab long travel there both 3.5 inch I did notice that total chaos for our 3rd gen rigs also has a adjustable upper and lower and panhard bar kit for the rear... Is there pluses and minuses to both brands or kits?
AntonioCm1983 is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 09:58 PM #11
Mcm actually had a few more extra options on there site are a little bit cheaper on some things over Srq Fabrication I'm kinda torn between mcm fab and total chaos fab for there long travel kits I keep looking more at total chaos because they also have adjustable rear upper and lower control arms as
as the panhard bar is adjustable thought between both these brands and pluses and minuses would be amazing issues or problems with either kits or brands I know total chaos don't come with cvs or rack spacers or coil overs couldn't find adjustable rear upper and lower control arms or panhard bar with mcm fab
Mcm fab website below hope it helps others
MCM Fab 96-02 4 Runner Long Travel - MCM Fab & Design
Pricing:
Sold here: Page not found
Coilover options:
Included in kit:
Limiting straps
Specifications:
13” of wheel travel
4wd compatible
Install:
All laid out
The install
FOA coilovers
Finished product:
Thoughts so far:
Old 09-25-2021, 11:34 PM #12
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I made a thread a while ago doing a very light comparison of all the available LT kits on the market for 3rd gen T4r’s. Just good to see all the options out there. Not sure if it will be helpful to you or not but figured I’d post the link for you..
All long travel options
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 11:08 PM #13
3rdgensnowhite 3rdgensnowhite is offline
3rdgensnowhite is on a distinguished road
Thats awesome man! im currently building my own Lt kit.
Follow me in IG @ DWFAB_21
3rdgensnowhite is offline   Reply With QuoteReply With Quote
Old 03-04-2022, 04:08 PM #14
koltoncj koltoncj is offline
koltoncj is on a distinguished road
Subbed!
koltoncj is offline   Reply With QuoteReply With Quote
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
"Coil slap" with Metal tech long travel kit TORCH 4th Gen T4Rs 23 04-26-2017 02:15 PM
GA-BNIB 2" Total Chaos "Race" Long Travel -Cam/Bucket/Spindle Gussets -Axles/HD Boots av8ter For Sale: Suspension/Wheels/Tires 24 02-26-2017 05:07 PM
Disappointed In Rear ToyTec "Long Travel" 5100's Tyler James Inc 3rd gen T4Rs 19 11-17-2016 05:48 PM
CVJ "long travel" inner boot torn after low mileage ARC 3rd gen T4Rs 14 10-13-2015 12:14 AM
