Old 08-22-2019, 01:42 AM #76
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by TonyB66 View Post
How much does that shackle stick-out? This is the license plate holder I got, and it allows for 2.75" behind, likely not enough, so it would be angled upward somewhat...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I had that exact same license plate mount before switching to this AWS. It definitely bugged my OCD more so than having the license plate partially obstructed like it is now. Probably end up fabbing something up to reuse the mounting plate that fits behind the hawse fairlead, because OCD.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 01:12 PM #77
jearred.foruria jearred.foruria is offline
jearred.foruria is on a distinguished road
RAD build bro!!
jearred.foruria is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 06:19 PM #78
Real Name: Scott
Real Name: Scott
Small Update
Finished the 500 mile break-in of the new front diff, so did an oil change along with the drain and fill of the front diff. Seemed like the metal particles on the diff drain plug magnet were pretty normal:
Only had about a bottle and a half of the Lucas 85w-140 dino gear oil to fill it back up with and after pumping it all out into the diff, it didn't start dripping out like I usually like to see. Good opportunity to use the bore scope to double-check:
Looks good:
Grit looks okay:
On the "WTF" side, the drain plug was once again stuck in diff enough to end up stripping out the 10mm hex. Again had to use the Irwin extractor that was used the last time to get it out. This time though, I don't have a replacement, so I've got one on order from Amazon. Sucks I'll have to drain and refill it again. I'm starting to wonder if 48 ft-lbs is the correct torque value:
What I'm thinking is to use the old plug (which was new as of about 9 months ago) and weld a nut to it and use that going forward. This way the new plug that's on order can be used as a backup in the case that I can't get it welded on there well enough. Can anyone confirm that these are 1.25 pitched 24mm plugs? Also thinking about just ordering something from McMaster-Carr and doing away with the stupid 10mm hex!
Last edited by weekendclimber; 09-19-2019 at 02:53 PM. Reason: added picture of grit on magnet
Old 10-29-2019, 01:20 AM #79
Real Name: Scott
Real Name: Scott
Little video of installing the dual battery tray I put together. Going to try to do more of these in the future.
Old 12-04-2019, 01:30 PM #80
Real Name: Scott
Real Name: Scott
Here's a video I put together to go over replacing the stripped front diff drain plug. Hope this helps someone out in the future.
Old 12-04-2019, 02:16 PM #81
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
did you buy that irwin kit in a store? if so, which one?
i have a stripped drain plug and i need to get it out. i have a welder and i spare tool to weld to the plug so i will likely try that. if i can buy this locally i will consider buying the kit. i dont want to buy online incase it doesnt work for me and i have to return it (these kits either seem to work incredibly well, or not at all for me). ive already sent two (non car related) packages back for returns this week and its a PITA to keep track of everything.
edit: i saw it once and then i couldnt find it again. why did your weld break? not good enough penetration?
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 12-04-2019, 03:06 PM #82
Real Name: Scott
Real Name: Scott
It's the Irwin Multi-Spline Extractor Set #53227. This is the full kit, but I ended up using only the 7/16" extractor for this specific need. I think you can get a smaller 5 piece kit with that one included. IMHO, they are handy to have around to extract stuff when needed.
Yeah, I've only got the 125amp HF flux core welder, so it just wasn't enough umpf to penetrate the drain plug to get the sacrificial 10mm hex socket to stick.
Old 12-04-2019, 03:23 PM #83
ah i see thank you. my roommate has a welder that is hooked up to gas and can weld up to 1/2" thick plate; so i will likely go that route just for the sake of not spending money.
IG: mesooohoppy
Old 12-04-2019, 03:38 PM #84
Real Name: Scott
Real Name: Scott
As I'm sure you know, that heat should also help. Not sure if you're considering it, but you may want to reuse that drain plug since it'll already have that welded on. As shown in my video. On a brand new diff along with a drain plug less than a year old, it was already stuck after only about a month and a half. I'm going to be welding a nut onto the old stripped drain plug for future use if I have the same problem.
Old 12-04-2019, 03:38 PM #85
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
If I'm not mistaken, both front and rear diffs and the transfer case drain and fill plugs share the same m18x1.5 thread. Earlier this fall when performing my 4runner's annual service I had the fill plug round out on me when checking the fill level, even with a Snap-On six point socket. It's inevitable, sooner or later they fail.
Anyway, I didn't like the dealer price for a replacement so I sourced a plug and gasket through Dorman. The plug has a much more substantial hex, and the gasket is made from a synthetic. Cost me less than $3 at my flaps. I don't see another problem with it in the future. Dorman #090-042.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 12-04-2019, 03:47 PM #86
Real Name: Scott
Real Name: Scott
I don't think it's 1.5 thread pitch, but I could very well be wrong. Seems more like a 1.25 to me from what I remember. Memory is getting bad though.
Edit: I'll check tonight with the old stripped plug and report back.
Old 12-04-2019, 03:53 PM #87
Either way, a superior replacement should be available. The OE design on these plugs sucks.
_________
Old 12-04-2019, 04:53 PM #88
while i agree that if youre going to do a hex style design, it should be atleast a torx type with plenty of depth to allow for proper bit engagement.
i have a small trick that may or may not help you with these hex caps. if the fitment between the hex key and plug is a little sloppy, take your hex/allen socket and wrap 1 layer of painters tape around it. this should take up all the 'slack' per se. i have done this in the past and its worked out great.
IG: mesooohoppy
Old 12-06-2019, 12:22 PM #89
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
wow. quite a build you have going. thanks for all the pix and exposure to possibilities. time to subscribe to your thread ;-)
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 11:40 AM #90
Real Name: Scott
Real Name: Scott
Rear Lower Control Arm Bushing Replacement
Even though I've got Sonoran Steel HD rear lower control arms, I've kept the old ones around. Going to be using them as trail spares, but wanted to at least get the old bushings out and replace them. I put together a video on how I press these out and I believe it's mostly based on @mtbtim and @infamousRNR 's experience. You should definitely watch their video for a more thorough explanation that includes removal from the vehicle (YouTube)
Tinkergnomes Clone Trooper build thread Tinkergnome621 3rd gen T4Rs 1 10-11-2012 10:40 PM
Sport Ed Roof Rack -- Bolt on to SR5 or Not? ... Aftermarket Clone? webby 4th Gen T4Rs 7 04-11-2011 07:31 PM
1996 limited dark green with auto and new tires nicksdad New Members 2 09-12-2010 01:20 AM
4 SALE - 1994 Toyota 4runner 4X4 V6 AUTO GREEN scottes So Cal 0 01-18-2008 07:07 PM
