Old 05-05-2017, 04:57 PM #1
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
Can't get brake rotors off. What am I forgetting?
I'm changing front pads and rotors. I've got wheels off, calipers out of the way. Rotors are supposed to slide off, right? What am I forgetting?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 05:08 PM #2
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
A hammer. Tap the rotor in a few spots to loosen it up. If that doesn't work get a BFH. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 05:24 PM #3
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Been beating the hell out of it with a BFH. If my rotors weren't warped before, they sure are now.
Old 05-05-2017, 05:24 PM #4
ltsr's Avatar
ltsr ltsr is offline
ltsr is on a distinguished road
ltsr's Avatar
Sometimes the small screw holding the rotor to the hub is still in place. You might have to take a closer look to see if the philips head screw is there. It sits flush with the rotor so it may not be easy to spot.
ltsr is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 05:28 PM #5
What screw? I just did the TBU 2 weeks ago and there is no screw on the rotors.
Old 05-05-2017, 05:29 PM #6
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
I don't think 4wd has that screw? I didn't remove any screws last time when I did the Tundra brake upgrade.
Old 05-05-2017, 05:32 PM #7
Did you put anti-seize on the back of the rotor last time you did them?
Old 05-05-2017, 05:35 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Hammer on the flange around the studs because that's where the rotor gets locked onto the hub. Just don't swing wildly and smash the studs.
Old 05-05-2017, 05:51 PM #9
ltsr's Avatar
ltsr's Avatar
Most people don't put the screws back in after the first rotor replacement. Unless you're the first owner and never replaced the rotor, its most likely been removed. Yet, I could be wrong these trucks never came with screws on the rotors but that's unlikely.
Old 05-05-2017, 06:08 PM #10
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
That sucks.
I just did mine and was thrilled at how easy mine came off.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 06:12 PM #11
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
I had to use a technique like the one shown in this video last time I removed my rotors....BFH would not do the trick....this is much more elegant...
https://www.youtube.com/watch?v=mtsTJCRljAs&t=242s
Also - not to worry....no screws secure the rotor as they do on some cars (i.e. my Honda Accord)...
Buckaroo
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 06:15 PM #12
Buckaroo
Good idea.
Old 05-05-2017, 06:16 PM #13
I can't speak for other years but on my 98 there in no hole for a screw in either the rotor or the axle hub. The exploded view in the FSM of the front axle hub doesn't show any screw either.
Old 05-05-2017, 06:41 PM #14
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
No holes in the rotors for me.
Usually an air hammer can make quick work of it.
This has always worked. If it doesn't pop off right away, leave it under tension for some time and let nature work its course....
https://www.youtube.com/watch?v=7IQ8Hf2UiAE
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 06:56 PM #15
flipty flipty is offline
Real Name: Dave
flipty is on a distinguished road
Real Name: Dave
Just keep on hittin' em. They'll come off eventually I've had a few in my days that took unbelievable amounts of one-hand sledge. But they all came off.
flipty is offline   Reply With QuoteReply With Quote
Need brake rotors tnfirefighter 4th Gen T4Rs 13 04-21-2016 09:10 AM
Brake fade after new brake pads and rotors tjhaf2007 4th Gen T4Rs 4 07-21-2014 12:05 PM
FS: 3rd Gen Brake Rotors, $20, PSL FL daMicr0wav3 For Sale: Suspension/Wheels/Tires 0 05-17-2014 09:44 AM
3rd Gen. Brake Rotors Sheepdog 3rd gen T4Rs 6 07-01-2013 10:21 PM
Do I need new brake rotors? trdrun 3rd gen T4Rs 19 03-09-2012 04:36 PM
