Old 05-09-2017, 08:14 PM #1
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
Leaking coolant from reservoir after driving more than 15 mins
So I've been leaking coolant on a hot day and driving for a bit. I replaced the tank and filled it back but still leaks. The truck won't overheat or anything but it seems to rev a little louder than normal under 25mph.. I know I need to replace the timing belt and water pump and probably thermostat soon. Any ideas why I'm leaking?
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 05-09-2017, 08:38 PM #2
reelamin's Avatar
reelamin reelamin is offline
reelamin is on a distinguished road
reelamin's Avatar
Replace your rad cap.....if it continues...put a pressure gauge on it. Don't panic it's probably not a head gasket....LOL...just had to say that.
He who Shi% fast does not Shi% for long!!
BILSTEIN CUSTOMER SERVICE SUCKS MUNG COVERED BALLS!!!
reelamin is offline   Reply With QuoteReply With Quote
Old 05-09-2017, 08:51 PM #3
jman11788's Avatar
jman11788's Avatar
I'm so worried it could be a head gasket lol!
Old 05-09-2017, 11:51 PM #4
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
The coolant is being pushed into the resivior?? Hmm...does it get sucked back into the radiator when cool? If no, then it could be a blown headgasket. Another thing...are there bubbles in the resivior when the truck is warm?
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 11:49 AM #5
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Is it "leaking" out the overflow hose on the reservoir or is the level going down in the reservoir?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 12:16 PM #6
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
OP, you need to give us more details for us to be able to help you.
Where exactly is it "leaking" from? That would be a good start.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 12:59 PM #7
jman11788's Avatar
jman11788's Avatar
Pretty sure I said its leaking from the tank. It'll spew out of the cap. It'll drain out almost all of my coolant and It will be close to empty when it's done leaking.
Old 05-10-2017, 01:05 PM #8
Does the temp gauge ever move above the center mark? A scangauge, ultra gauge or similar OBD reader can also tell you actual water temps at the outlet of the motor - it might help the diagnosis.
I'd start with the easy one, like reelamin said - radiator cap, OEM only! If the system can't hold pressure, it will boil near the cylinders and push coolant out the radiator cap, fill the overflow and come out the vent on the overflow.
You can also test for exhaust gasses in the coolant, but that is less likely.
If the other stuff is due (radiator, hoses, thermostat with jiggle valve at 6 o'clock, water pump, etc.) then do that next.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-10-2017, 01:06 PM #9
jman11788's Avatar
jman11788's Avatar
Going to the dealer to get a new rad cap. We"ll see how it goes
Old 05-10-2017, 01:21 PM #10
thegipper's Avatar
thegipper's Avatar
You just said you replaced the tank but it still leaks, I didn't see any mention of the cap. No biggie, just wanted to make sure we knew exactly what was going on so we could better help you.
I would do what Phattyduck said, that is a good start.
2011 Camry SE V6
Old 05-10-2017, 01:33 PM #11
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
I had the overflow tank boil over once when I overheated going up a hill. All due to a bad radiator cap I believe. Pisses me off that something so small can cause overheating and possibly longer term head hasket problems. Same with those stupid coolant lines underneath going back to the rear heater which rust out on earlier year models (later years are alumjnum). When they finally do leak you lose your coolant and overheat the engine. I think I have a compromised head gasket all because of this.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 01:42 PM #12
thegipper's Avatar
thegipper's Avatar
^This is exactly why I bought an Ultragauge to monitor engine temperatures. I have an alarm set on it for 215degrees. If I ever hear that alarm go off, I'll immediately pull over and shut it down. The gauge on the dash is completely worthless until it's too late.
Best 80 bucks I've spent in awhile...
2011 Camry SE V6
Old 05-10-2017, 02:56 PM #13
jman11788's Avatar
jman11788's Avatar
Well just got back from the dealer to pick up my cap. Opened the hood as soon as I parked it and the overflow tank is boiling.. this does not look good.
Old 05-10-2017, 03:03 PM #14
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Compare the old cap with the new one. The OEM caps are known to fall apart and the small center plastic cap and spring end up somewhere in the top of the radiator. If your old one was missing parts, it wasn't holding pressure like it should.
Old 05-10-2017, 03:08 PM #15
jman11788's Avatar
jman11788's Avatar
As a matter of fact I took off the old one to inspect it and saw a piece stuck in the top of the radiator. Here's a couple pics
Leaking coolant from reservoir after driving more than 15 mins-img_3172-jpgLeaking coolant from reservoir after driving more than 15 mins-img_3173-jpg
Corrosion in Coolant reservoir mgcorreia 3rd gen T4Rs 14 04-20-2014 09:42 PM
Corrosion in Coolant reservoir mgcorreia 3rd gen T4Rs 0 03-30-2014 08:24 PM
Coolant reservoir dirt?! atalarico 3rd gen T4Rs 11 09-20-2013 09:42 AM
Brake fluid reservoir leaking 4runnerTiger 3rd gen T4Rs 0 11-15-2011 12:42 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
