Old 06-05-2017, 10:53 PM #1
wslytoy wslytoy is offline
Real Name: Wes
wslytoy is on a distinguished road
Real Name: Wes
Rabbit hole? 5VZ experts...
Where does this hole go?
For orientations sake, this is the front driver's side cylinder head in front of the cam... Behind the front ½ moon. Pulled the ½ moon & a very small piece broke off & conveniently​ fell into said hole.
Sent from my ONEPLUS A3000 using Tapatalk
wslytoy is offline   Reply With QuoteReply With Quote
Old 06-05-2017, 11:14 PM #2
RockyrT4R's Avatar
RockyrT4R RockyrT4R is offline
Real Name: Christian
RockyrT4R is on a distinguished road
RockyrT4R's Avatar
Not sure but hopefully you can get it figured out!!
Owner at Sawtooth Offroad Fabrications | 99' LTD V6 Millenium Silver w/E-Locker | AOR Bumper | “Bandit” Dual Swingout Rear Bumper | SlimsDepot 55w 6000k HID’s | 315/75R16 Falken AT3W
Instagram: @rockyt4r
RockyrT4R is offline   Reply With QuoteReply With Quote
Old 06-05-2017, 11:17 PM #3
4Reak Show's Avatar
4Reak Show's Avatar
Pretty sure it's an oil drain hole. I wouldn't lose sleep about it.
Old 06-05-2017, 11:38 PM #4
Real Name: Wes
Real Name: Wes
Hell of a spot to put a hole, right? Ha!
If it's gonna happen to someone, it's gonna happen to me. Some chunks broke off, as you can see. I got most of the broken pieces out, b/c they were still attached to silicone on the cylinder head. Just 1 little chunk fell. I guess my #1 concern is it causing an issue w/ the rotating assembly, mainly the crank bearings​ or something lower end related. I can actually see the little piece of aluminum, but of course I can't get it w/o removing the head. Which seems excessive... After I get this chore finished, I'm changing the oil anyway, so if I can flush it out the pan w/o any issues... That'd be ideal. May even rig up something w/ the shop vac ha!
Old 06-05-2017, 11:45 PM #5
I'd say it a drain hole also. Were they on that tight they ended up like that trying to remove them? Mine were well lubricated. I just picked mine out by hand.
You could get a small syringe and try and force oil and get it in the pan and drain the oil
Old 06-05-2017, 11:45 PM #6
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
is that magnetic? if it is, maybe you can tie a small magnet to a wire or something to get the small chunk that fell into the hole
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 01:01 AM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I'm sure that there is a surgical instrument that has illumination, a grabber clamp, and HD video and is small enough to go down that hole, but you'd have to know a good surgeon...or maybe own a hospital... to borrow one.
If it's plastic or rubber, it'll just get ground up by the mechanism. The only concern is that it might block or partially block a narrow oil passage.
If you could personally examine a clean copy of the head (off of vehicle,) you could ascertain the nature of the passage.
pluton is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 01:22 AM #8
amalik amalik is offline
amalik is on a distinguished road
if a shopvac doesn't work, i'd drain your oil and go from there.
amalik is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 08:52 AM #9
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Shop Vac good idea. Take it a step further and duct tape a 1/2" or so diameter hose to Vac hose, increases vacuum 10 fold.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 06-06-2017, 10:43 AM #10
sawguy sawguy is offline
sawguy is on a distinguished road
You could try a long toothpick like skewer and wrap a small piece of double stick tape to the end, or try to snag it with a Q-tip.
sawguy is offline   Reply With QuoteReply With Quote
WTB; Hat w/rabbit that plays ukulele... -anywhere the great him Want to Buy/Trade 4 05-11-2014 11:13 AM
Butt hole moved after Body lift (Spare tire access hole) KSWAY 3rd gen T4Rs 3 03-13-2013 11:09 PM
Help from the experts Frankhenrylee 3rd gen T4Rs 7 08-31-2010 04:51 PM
