Old 06-06-2017, 01:34 PM #1
dogbreath650's Avatar
dogbreath650 dogbreath650 is offline
dogbreath650 is on a distinguished road
New trans cooler and radiator - should I get rad for manual trans?
Got a new 98 T4R Limited with 160k miles. Although prior owner last did a coolant flush at120k I thought I'd establish a new baseline with new parts so I know what I've got. I'll be doing the timing belt replacement so thought I'd change out radiator since I have to remove the old one anyway. For added insurance against the pink milkshake thought I'd also add a trans cooler.
My question is, should I order a new radiator for a manual trans since I don't need the trans cooling anymore as part of the radiator or should I just order the normal one for an auto tranny and cap off the trans coolant lines?
Thanks
dogbreath650 is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 01:50 PM #2
Airmapper's Avatar
Airmapper Airmapper is offline
Real Name: Travis
Airmapper is on a distinguished road
Airmapper's Avatar
Real Name: Travis
Seems like I read somewhere no matter what you order you get one for an auto. I can't recall where but that stuck in my head for some reason. Makes sense though as the Manuals are rare and the Auto radiator works the same, so why stock 2 of the same part with one irrelevant, low volume, variation.
2000 Toyota 4Runner Limited
Photo Album - Build Thread - YouTube Channel
Airmapper is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 02:07 PM #3
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Thats what I remember too. I guess it depends which radiator you go with, but Rock Auto seems to have all three core height sizes- with and w/o the trans cooler nipples.
https://www.rockauto.com/en/catalog/...,radiator,2172
You have to look under the 4cyl Tacoma to see all the options.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 06-06-2017, 02:14 PM #4
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
I would just get with and cap it off. You never know when a situation comes about and you'd decide to ditch the external cooler (maybe it splits or gets damaged on the trail). Then all you have to do is connect the hoses to the one in the rad and keep on truckin' with cooled fluid.
Or, you may decide that the external cooler alone isn't ideal for your climate/duties and want to run it in series with the OEM cooler.
Point is, you'll have a new rad. Even without a segregated external cooler, you won't have to worry about the dreaded pink milkshake for another decade in the least.
But again.. I would just order with. leave you with options for whatever situation down the road.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Radiator, Trans. Cooler, or both.... Airmapper 3rd gen T4Rs 36 11-15-2017 04:50 PM
Radiator w/ No Built-in Trans Cooler jeff88 3rd gen T4Rs 2 05-14-2017 02:09 PM
Radiator replacement after trans cooler install browebb General Discussions 3 10-13-2015 05:15 PM
FS: New 4th Gen Denso Radiator + New B&M Trans Cooler 70264 BunMaster For Sale: T4R Items 0 08-08-2015 02:38 PM
trans cooler done - radiator questions rvschulz Maintenance/Detailing 1 10-27-2010 11:56 AM
