Old 06-09-2017, 07:32 PM #16
Originally Posted by gamefreakgc View Post
I've learned the hard way the deckplate mod is not smog legal in CA. But seeing that I run a 99 box in a 98 with the smaller MAF and blah blah blah, I bought and extra unmodified 98 box and MAF to put in to pass smog, then take back out. If you are concerned about passing smog, remove the elbow in the fender instead.
I was always under the impression that modifications to the 'dirty' side of the air intake system were legal. I did some searching and couldn't find a good link/explanation one way or the other though.
I did just pass with a deck plate (closed) at a pretty thorough smog place...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-09-2017, 08:20 PM #17
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Seems the deckplate and ISR mods are both heralded and scorned, depending on the audience
Isr mod new info, must read!!!!!
If I find a decent airbox in a junkyard one day I might try the deckplate mod, but I like the idea of screening it to keep birds and boulders out, regardless.
A friend of mine had a dual headlamp goat that he converted to single hi/lo bulbs and ran intake scoops to the second headlight hole from a closed air filter housing.
The idea was MPH forced induction and lower intake air temp rather than breathing "hot" air from inside the engine bay. My seat of the pants dyno didn't register much difference.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 06-09-2017, 08:38 PM #18
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
With that picture, depending on the CFM of the carb used, it wouldn't make much of a difference, if any. The carb would be the bottleneck
Sent from my SM-G900V using Tapatalk
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 06-09-2017, 08:45 PM #19
Carb and throttle body are bottleneck #1
Cam timing is bottleneck #2
Cylinder volume is bottleneck #3
Chamber volume is bottleneck #4
Chamber swirl and quench is bottleneck #5
Unless the engine's components/characteristics are designed to operate under certain conditions, changing a single parameter after the fact usually creates negligible results, or introduces new problems. In my experience.
Old 06-09-2017, 09:19 PM #20
Real Name: Daniel
Real Name: Daniel
Haha well, sure, if you wanted the long, more in depth, more accurate version.
Old 06-09-2017, 10:06 PM #21
Haha, the devil is always in the details
All the chevy performance/hot rod mod mags went crazy over factory vortec heads when they first showed up on chevy trucks. BOLT ON 40 HP, they said. The frenzy at the junk yards was on, it was a blood bath.
But unless you had a dyno and were building with the intended design in mind (and had the right casting heads) you might as well have turned your ride into a pig. You need to use domed pistons and the set the quench pad just right with a shim gasket, plus California only has 91 octane. Run anything less than 9.1:1 compression or 93 octane and you'll eventually detonate yourself into a new engine with every pedal stab.
Similar with GT40 heads on 289/302 fords.The head flows great, but the chamber was actually higher volume than stock heads, so you lost compression. Can you say turd magnet? But put those same heads on a 351 Cleveland with flat tops, 1.7:1 roller rockers, an .030 gasket with a decent cam and you have a 400 HP (at the crank) motor on 89 octane.
Then one also needs to consider trans gear ratios and rear end gear/tire size to make a winning combo, but that's another story
Old 06-10-2017, 02:13 PM #22
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yeah, each smog tech is different. I was [un]lucky to get a veteran who knew the smog regulations and could literally quote them. He said that if the airbox had any cracks or openings it did not mention repairs, but "it must be replaced with a non-cracked or altered box". New airbox for me
There's plenty that also pass smog with the 7th injection and other "illegal" mods but I have not had such luck.
326WHP 347TQ
Old 08-07-2019, 12:11 PM #23
Dementedfish's Avatar
Dementedfish Dementedfish is offline
Dementedfish is on a distinguished road
K&N filter ok to run?
Resurrecting an old thread here. I’m currently running the stock intake with a k&n drop in. Sounds like a few people recommended not using one when running the deck plate mod and replacing it with a oem style filter instead. Any particular reason for this?
2000 4Runner 5-Speed 4x4 TRD Supercharged
Dementedfish is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 12:21 PM #24
Real Name: Jerod
Real Name: Jerod
Since it's actually drawing in some air from the front of the vehicle at speed, it does collect a little bit more dust on the filter. But that's why you have a filter... don't listen to paranoid people and go enjoy it! You can always close the deckplate if it's that dusty.
I also have an oiled filter and the deckplate mod.
326WHP 347TQ
Old 08-07-2019, 09:47 PM #25
SnowLizard's Avatar
SnowLizard SnowLizard is offline
SnowLizard is on a distinguished road
SnowLizard's Avatar
I have yet to do the deck plate mod... I still have it... just haven't done it...
but for the filters I will say this... I LOVE not having to worry about oil on my filter, 50% of the time, after a long dusty-dirty offroad, I can 'bang' lightly my filter and ALOT of dust comes out. IDK about you, but I'm sure the oil based filters can't clean most of that out cause it's sticking to the oil... I am running Toyota brand air filter (denso).
this is my opinion, you're entitled to disagree...
1999 3rd gen Ltd 4wd 3.4 auto dif lock - Build Thread SOLD!
2019 Tundra Sr5 CrewMax - 1 owner
Doubt kills more dreams than failure ever will.
SnowLizard is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 10:12 PM #26
Real Name: Jerod
Real Name: Jerod
K&N's do have the lowest filtration rate among major filter manufacturers. It's hard to reproduce real world situations seen by a filter but there's been some good attemps that show this. So your point does have merit. It really depends on how you use your vehicle though. If you don't offroad much (I don't) or live in a wet climate where dust is not very common, it will not factor in as much as it would for a overlanding rig that sees dirt all the time.
I have an aFe oiled filter, which in the same test filtered out twice as many small particulate than a K&N. Still less than a paper filter but pretty darn close. I gained +9 peak HP from the filter alone though... so I'm sticking with it.
326WHP 347TQ
Old 10-19-2020, 04:41 PM #27
bg_atx bg_atx is offline
bg_atx is on a distinguished road
Originally Posted by tystaco View Post
I used mesh screen inside my deckplate mod to help catch bigger stuff...because to answer your question, the deckplate mod faces straight at whatever you are driving into, so while I agree that dust can get in through your fender, you are sending more in at 60 mph head on with the mod. I had so much debris caught in my mesh screen that without would have been in the filter...
How/Where did you apply the mesh? I am considering doing the same.
bg_atx is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 05:51 PM #28
You can hot glue mesh to the inside of the fitting.
Just don't forget to close it in heavy rain or when fording streams.
Sent from my Pixel 4 XL using Tapatalk
Old 10-19-2020, 05:55 PM #29
gotcha! I'll grab some next time I'm at the hardware store. My problem is going to be remembering to cover during the rain. Thanks for the info!
Old 10-19-2020, 08:14 PM #30
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
Good info here:
Toyota 4Runner Highlander Deckplate and Air Filter Modification
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Anyone here know how to do a deck plate mod HawaiiTRD 3rd gen T4Rs 11 03-01-2014 04:39 AM
deck plate and isr mod 410toy 3rd gen T4Rs 23 07-08-2011 03:01 PM
Deck Plate mod. ric 4th Gen T4Rs 38 07-13-2009 12:37 AM
No deck plate for 03 V8? majewski 4th Gen T4Rs 2 03-08-2008 02:59 AM
What is a Deck Plate Mod? skymoney 3rd gen T4Rs 2 02-01-2008 11:46 AM
