06-09-2017, 10:17 AM
Real Name: C8H18 Mike
Deck plate mod, worth it?
Besides having to clean the air filter more often and stop to plug it during deep water crossings, are there any noticeable differences, like improved MPG?
Sent from my Nexus 5X using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-09-2017, 10:24 AM
Real Name: Phoenix
Real Name: Phoenix
No, it's been shown to give 7 horsepower at the wheels but you aren't going to feel that. Another alternative is to remove the elbow on the fender. That is proven to give the same increase without cutting a giant hole. IMO it's not worth it unless you are forced induction where the motor can take advantage of smoother airflow. When the motor is naturally aspirated the intake really works about as good as you can get.
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
06-09-2017, 10:53 AM
I just recently did it.
It was cheap and easy, but worth it? I am not certain. I don't feel anything.
06-09-2017, 10:55 AM
Well it's ~4% increase in HP for $10 and 30 minutes of your time. Why wouldn't you?
06-09-2017, 11:14 AM
Real Name: Tyler
Real Name: Tyler
I did it to my Tacoma back in 2011....never really blown away by it. It made more noise, sounded throatier which was cool, but cleaning the air filter more was something I wasn't keeping up on, so I put the plug back in.
1999 T4R Limited (Mine)
2000 T4R Limited (Wife's)
2004 Tacoma Xtra Cab TRD
06-09-2017, 11:22 AM
Agree with this. If you're SD'd or turbo'd, then the elbow of the intake can be pretty restrictive to the additional airflow. But under standard conditions, the difference is nominal.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
06-09-2017, 01:35 PM
Why does everybody think that moving the intake to the engine bay makes the filter dirtier faster?
The current air intake is in the FENDER WELL!!! Right above the tire! What happens there?!?! In the reverse - do you see dust, dirt, etc. build up between the airbox and headlight? Not so much. They are about equal with dirt on the filter. Just 'cause you can see the filter doesn't mean it will be getting dirtier faster.
And water crossings would have to be about even with the bottom of the headlight to get water in the airbox. So, for just about every situation but Aussie style river crossings, you have no worries.
I personally have done the mod and have it closed or not based on mood (daily driving, open... long trips, closed for less sound). It does get a bit loud on throttle with an ISR and the deck plate open.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-09-2017, 01:52 PM
Real Name: Tyler
Real Name: Tyler
I used mesh screen inside my deckplate mod to help catch bigger stuff...because to answer your question, the deckplate mod faces straight at whatever you are driving into, so while I agree that dust can get in through your fender, you are sending more in at 60 mph head on with the mod. I had so much debris caught in my mesh screen that without would have been in the filter...
06-09-2017, 01:53 PM
I bought my deck plate... but haven't installed it... have the ISR...
1999 3rd gen Ltd 4wd 3.4 auto dif lock - Build Thread SOLD!
2019 Tundra Sr5 CrewMax - 1 owner
Doubt kills more dreams than failure ever will.
06-09-2017, 04:47 PM
For years I have heard apocryphal tales of horsepower gains from the "deckplate mod."
The story goes that a bigger hole on the airbox lets in more air. More air equals more hp, right?
First, the stock airy intake is more than large enough to supply all the air the 3.4 can consume.
Second, the air supply (no not the crappy band from the 80's) the air supply is regulated by the Throttle Body. You can cut a hole in the hood. You can install an airbox 10 times the size of the stock airbox; you can do ANYTHING you want anywhere along the air intake BUT and the entire air induction system is limited by the size of the Throttle Body and the Throttle Body alone.
The deckplate mod is bunk...nonsense...a myth in the minds of many.
Yes, I know I have committed heresy among the true believers.
06-09-2017, 05:18 PM
Real Name: Jerod
Real Name: Jerod
Will try and keep my comments concise, since I like to talk performance
I've learned the hard way the deckplate mod is not smog legal in CA. But seeing that I run a 99 box in a 98 with the smaller MAF and blah blah blah, I bought and extra unmodified 98 box and MAF to put in to pass smog, then take back out. If you are concerned about passing smog, remove the elbow in the fender instead.
For my overboosted S/C engine, it is a noticeable power loss when I switch boxes with no deckplate.
Well said. I personally have never covered up the deck plate. And if you are worried about water crossings, put the plate back in and it's back to stock.
He's the hard data showing the deckplate does increase power:
On a supercharged engine: Air Induction - The founder and owner of URD.
On a stock engine: Project SportRunner - Deck Plate Mod - A resident forum member and performance enthusiast.
Enjoy.
06-09-2017, 05:46 PM
Just the sound is worth it. I can actually hear my motor when wheeling. Its nice to actually beable to hear and feel the revs instead of hearing nothing and needing to look at the tach.
06-09-2017, 05:58 PM
Real Name: Jeff
Real Name: Jeff
Sounds cool for sure. I did it on my '96 and after I installed the s/c it would throw a lean code whenever I had it open. I've decided to leave the air box as is on the '00.
3RDGENS.COM
My Video's
'96 Limited - October '08 T4R Of The Month (Sold)
'00 SR5 - Lifted/Supercharged/E-locker
'16 SR5 Barcelona Red
06-09-2017, 06:35 PM
Im up to about 16.5mpg, which is a 1.5/10% improv3ment in fuel economy. At hihway speeds for long drives, In pushing 18mpg with a full trunk of luggage and passengers.
Best $30 ive spent so far.
06-09-2017, 06:44 PM
Real Name: Just call me the Grease Monkey
Does the sound go back to normal when you put the plate back in?
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
