Old 04-04-2019, 12:28 PM #61
Henrythewound Henrythewound is offline
Henrythewound is on a distinguished road
Originally Posted by phattyduck View Post
The 5th gen wheels, along with the Tundra/Sequoia and FJ wheels all fit perfect with 265/70-17 tires, assuming your alignment is correct. Some of the later ('05+) Tacoma wheels require spacers to work and/or look good.
Make sure you have caster near the max range (3* or so) and everything will clear 100%. The next step up in tire size (285's) is where trouble starts.
Thanks! I was looking at these wheels as an option, I think they may be 5th gen (up to 2017 4Runner models correct?). I feel like some people have said these wheels have a different backspacing though. I'd hate to buy a set, mount them up, and then realize I made a mistake.
Henrythewound is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 01:55 PM #62
I am about to purchase some of the 5th gen TRD wheels which look just like the trail wheels with the recessed areas painted black. Any idea if my stock lugnuts from my 2000 4Runner will work with these or will I also need to purchase new lugnuts?
Thanks
Old 09-03-2019, 03:11 PM #63
PBR1 PBR1 is offline
PBR1 will become famous soon enough
Originally Posted by ConQueso View Post
255/80/17 Nitto Trail Grapplers, bilstein 5100 front and rear
@ConQueso are you running any spacers? I want to run a 3" lift with TRD 17" wheels on 255s but am wondering if I need spacers or not. I'm trying to avoid spacers but want a 33" tire.
PBR1 is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 01:09 AM #64
renegvde renegvde is offline
renegvde is on a distinguished road
Thumbs up
Question to you all! My 97 4runner has stock wheels 265/70/16. I just bought some trail wheels myself but i wanted to keep the stock height of the car. Would I need any spacers or do i need a lift of any sort or leveling kit to install some tires and ride comfortably with some all terrains? If so, what tire sizes would I be looking for that wouldn't cause me to add any sapcers, lift, ect.? All feedback would be appreciated!
renegvde is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 02:01 PM #65
Looks like you can get a BFG KO2 in 265/65-17, which would put you at the same rolling diameter as the stock tires. You can also do the minor upgrade to 265-70-17, which still should clear everything with no changes.
If you do get rubbing with the slightly larger tires, you can fix it with a decent alignment (the tech will need to move the caster to the max end of the allowable range).
Spacers are not needed unless you really go up in tire size (along with plenty of other clearancing).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-09-2021, 02:25 AM #66
4Reak Show's Avatar
4Reak Show's Avatar
I have a set of perfect Trail wheels for sale if interested
Old 03-10-2021, 05:36 AM #67
265/65/17
Is anyone running 265/65/17 with the trail wheels on their 4runner? any pictures uploads? Mines a 97 4runner awd sr5 and im looking to go with this set up.
Old 03-11-2021, 03:15 AM #68
4r3_yvr 4r3_yvr is offline
4r3_yvr is on a distinguished road
Trail Wheels on '97 Limited
Looking to mount these on a '97 4runner limited with ~1.5" lift. Tire size 265/70/17. The stock rims are ET15 w/ 4.5" BS. Curious to know if anyone has the Offset/backspace specs for the trail wheels. I believe the offset is 15mm.
4r3_yvr is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 10:37 AM #69
4Reak Show's Avatar
4Reak Show's Avatar
My research shows offset of +15. I’m not sure what that does for you, but that’s what I found.
Old 04-27-2021, 01:23 PM #70
4RunnerSpirit 4RunnerSpirit is offline
4RunnerSpirit is on a distinguished road
Any offers on those wheels?
4RunnerSpirit is offline   Reply With QuoteReply With Quote
Thoughts & Opinions (New Member) mferrell 4th Gen T4Rs 2 07-20-2014 03:06 PM
thoughts and opinions JamesDean91 3rd gen T4Rs 3 06-02-2013 05:16 PM
Thoughts and Opinions SoAZ4Runner 3rd gen T4Rs 7 03-27-2012 04:17 PM
Black Trail w/ Black Rhino wheels. Thoughts? 4RunnerTrail 5th gen T4Rs 1 01-11-2011 02:16 PM
Need Opinions/Thoughts dcinia 3rd gen T4Rs 9 05-26-2006 12:10 AM
