06-14-2017, 01:25 AM
Field Monitor Unit Install questions
I have been through a dozen threads on the subject and have two questions I cannot answer.
1) my unit only displays baro/altimeter, no temp. Mode button only affects altimeter mode...any ideas? Is this just a different version? Yes, it is wired up and hooked up to a probe.
2) unit does not dim with the dimmer adjustment. I tagged the green wire on the dimmer and all other lights hooked to this wire dim. I read in one thread it may be because I have installed LEDs...is this it? Something else?
Thanks!
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
06-14-2017, 08:48 PM
Any ideas?
1979 FJ40L-KC
06-15-2017, 02:12 AM
Take a better picture of your unit, but on mine the temperature is its own section, and the baro/alti is below it, cycling through via mode.
As for the bulbs, they actually are dimming but it's basically worthless (look very closely when you toggle your lights and you will see an incredibly minor dimming). Swap out to #2722 bulbs (T1-1/2), and you'll be set.
06-15-2017, 07:22 AM
Real Name: Charlie
Real Name: Charlie
Mode on mine only changes altitude. (high vs height ascended, from memory).
They don't Dim with LEDs. looks much better with factory replacement bulbs.
Mine is factory fitted (96), so I'd say its fair to say "that's how its meant to work"
Not sure about the temperature reading, didn't facelift trucks have it elsewhere, so it was removed from the field monitor?
06-15-2017, 01:09 PM
Real Name: Tim
Real Name: Tim
Originally Posted by Jason B
It would be very cool to find a way to get the temp to show in F. There's gotta be a way, or a jumper to soder or something to switch it,
Find one from a Subaru Forester and fit it in the 4Runner/Hilux mounting surround. It'll be in F and feet. The Subie units will mount into the DIN locations just fine if you'd want to go that route instead too.
Only "issue" is the picture is a tiny car
Build Thread
KE0MYV
1998 4Runner SR5 4x4
06-15-2017, 01:31 PM
Official Vendor
Official Vendor
are we positive it will install in the FMU housing?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
06-15-2017, 02:45 PM
Real Name: Tim
Real Name: Tim
Nope, but if someone is has an extra housing, I'd be more than happy to try and fit it.
Build Thread
KE0MYV
06-15-2017, 02:51 PM
Subaru Forester Impreza Altimeter Dash Compass Gauge Digital Multi Display #1
Looks like it will require a fair amount of modification.
I'm torn. I prefer hPa for pressure, but I'd like *F for temp. Hmmmm...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-15-2017, 07:22 PM
Thanks for the tip on the bulbs. Better pic as requested...thinking mine is just different. Cycling mode only changes between the altimeter modes for me.
FWIW it was gray and I repainted with some paint I had from another project, little light in color but good enough for me.
1979 FJ40L-KC
06-15-2017, 08:03 PM
Yeah, gotta say I think yours is just different
10-19-2018, 04:40 PM
I just installed a FMU in.my 98 4runner. Is is like yours. No temp, just baro and altitude
4.7L V8 swap
99 Tacoma 4.7L v8- 5 speed swap- Multi mode t-case, FZJ80 elocker axle, 35 M/T-R Kevlar- Toytech Coils- Bud Built skids
87 4Runner "Puppy Mill" 22re- Dual stock cases, SAS, Lock F&R, bob'd 13", Custom NCTTORA dent package
10-19-2018, 04:56 PM
4.7L V8 swap
10-19-2018, 08:54 PM
Real Name: Samuel
Real Name: Samuel
@ Chim
usually has a couple
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
