12-12-2019, 03:31 PM
#61
Real Name: Adam
Real Name: Adam
Current progress. These are the donors. Once the heads and covers are cleaned I will start disassembly of my engine. Then I plan to rebuild this one as a spare. So far, I've got about $500 &24 hours labor invested. That includes donor vehicle and parts ordered to date (gaskets, head bolts & washers, cleaning solvents, etc).
Sent from my SM-G965U using Tapatalk
'01 4wd SR5 w/ lots of FUN left to give
‘05 SR5 Sport
12-12-2019, 03:46 PM
#62
Real Name: Ron
Real Name: Ron
It's not that hard to destroy the threads in an aluminum head, even if the plug was not over torqued. The spark plug is steel, so it's going to win any fight with the aluminum. Usually what happens is that, if the plug has been in for a while, especially if anti-seize has not been used, the aluminum threads start to gall (roll up, basically) due to the friction with the spark plug. If you then keep applying torque, the aluminum threads will stick to the plug, and come out with it, leaving a hole with little or no thread left.
The secret is to be patient. Usually the plug will break free readily, and then get hard to turn a half-turn or so later. When that happens, the instant you feel the removal resistance increase, immediately reverse your ratchet and turn the plug back in a small amount. Then try backing it out again. You'll probably get a couple of degrees further, and then will have to repeat the process. Sometimes it may take 20-30 cycles of this to remove the plug, but it usually eventually works. If you just try the brute force method on a tight plug, you almost certainly will destroy the threads.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
12-12-2019, 05:19 PM
#63
Real Name: Jerod
Real Name: Jerod
Originally Posted by Adamdmc
Alright folks, started the teardown of the donor engine today. Finally got the head off, however I ran across something a little baffling though. The head was full of burt oil that closely resembles ash. Any ideas on what problems that this engine could have that would cause this?
That would be engine sludge, old stuff by the looks of it. Looks like they never changed the oil or the PCV valve was completely gunked up.
It's a delicate operation to remove it but you could try soaking in solvents and see if that loosens it up enough to wipe it off. You definitely don't want it in your new engine though.
I highly recommend switching to synthetic oil if you do indeed end up using that engine. It helps breaks down sludge slowly over time so it doesn't clog the oil pickup screen.
12-14-2019, 10:29 PM
#64
Real Name: Adam
Real Name: Adam
‘05 SR5 Sport
12-15-2019, 12:59 PM
#66
Take the crank pulley and the lower timing cover off and use the mark on the crankshaft sprocket instead.
As far as stripped out spark plug threads, I find that usually it is caused by under tightened plugs unscrewing to the point that they blow out, not over tightening or lack of anti-seize lube. This can be easily fixed on the vehicle in minutes with a spark plug thread repair kit. Comes with a tap that reams out the hole to an over sized thread, 2 or 3 different length thread inserts and a tool to set the insert so it won't come out.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
01-06-2020, 09:39 PM
#67
Real Name: Adam
Real Name: Adam
Well, I finally got it all back together. Since I knew that everything was good to go with the exception of the spark plug threads, I decided to just get the insert put in and roll out. Now I have a new problem, a break cant be had. It has a bit of a slip. Not as regular as a cylinder missing every time, but more intermittent. It seems to smooth out while driving, so it's not a dealbreaker, just want to get it right. Any suggestions?
By the way, I decided to heed everyone's advice and set the timing to "0" @ TDC.
‘05 SR5 Sport
01-06-2020, 11:44 PM
#68
Real Name: Jerod
Real Name: Jerod
Check for a vacuum leak. Will notice it most at idle and low throttle.
01-07-2020, 02:08 PM
#69
Real Name: Adam
Real Name: Adam
What is the normal idle speed? I'm idling between 675 and 725.
‘05 SR5 Sport
01-07-2020, 02:44 PM
#70
Real Name: Adam
Real Name: Adam
Now I'm getting a cylinder 4 misfire code. I can clear it and it will take 3-5 min for it to return so figured I'd try some stuff. I've tried swapping the #1/4 coilpack with the #3/6 coilpack and it persists. Undid that and just slaved in a plug wire from my donor engine, and it persists.
‘05 SR5 Sport
01-07-2020, 03:25 PM
#71
Real Name: Adam
Real Name: Adam
Sorry that I'm posting so many times, but this should be it for a while, at least. I have found the problem. Apparently some bonehead (me) didn't pay close enough attention when installing the spark plugs and one of the grounding tangs got buggered. Now that I've got that sorted out, she's purring like a kitten.
‘05 SR5 Sport
01-07-2020, 03:44 PM
#72
how is that even possible? did you drop it? did it come from the factory that way?
99 4runner limited; imperial jade mica
IG: mesooohoppy
01-07-2020, 04:07 PM
#73
Real Name: Jerod
Real Name: Jerod
Yeah that would do it! Basically you had no spark and running on 5 cylinders, I bet it did run rough! Glad you figure it out and it was just a $3 fix.
01-07-2020, 04:22 PM
#74
Real Name: Adam
Real Name: Adam
I'm assuming that maybe I dropped it I to the hole or something, but I do know that it didn't come out of the box that way. I verified the gap on all 6 plugs. I didn't even have to replace it, I just bent it back out and reset the gap to the 0.043" that the book calls for.
‘05 SR5 Sport
01-26-2020, 06:15 AM
#75
Real Name: Adam
Real Name: Adam
Hopefully this is the last update on the spark plug that blew out. After getting everything reassembled and ironed out it has been running Fantastically. I would dare say that it runs as smoothly as when it was new. And about the previous questions on timing, I'm so glad that I followed everyone's advice and set it to zero and not the 15 degree advance that it was. Seems to have better throttle response than before. Now on to refreshing the suspension and steering.
‘05 SR5 Sport
