06-15-2017, 10:37 PM
Real Name: Mitch
Real Name: Mitch
Spark plug blew out - helicoil?
So yesterday the plug in the middle on the driver side (#4?) blew out. That plug has been in there 2+ years. I put a new one in and it drove fine for day. Today it blew out again and the threads won't catch on a new one. I bought a tap, covered it in grease and ran it through a couple times and it bites the threads but the spark plug still doesn't bite. I think I can feel the spark plug threads drag along the threads in the head so I'm pretty sure I'm ****ed.
Has anyone done a helicoil at home? It doesn't seem to be the most complicated thing in the whole world. I want to give it a shot.
06-15-2017, 11:14 PM
Real Name: Dalton
Real Name: Dalton
Helicoil is pretty simple, I'd be concerned that metal shavings got inside your engine as well.
2001 4Runner SR5 2WD on 35" BFG KM2
Bilstein 5100/Toytec Springs LC 9 wrap/LC shocks.
Its a wannabe 4WD.
06-15-2017, 11:16 PM
Not on a 4runner but on a Honda Civic. It held for some time but after 20,000 miles it went. In reflection, my brother and I should have just bought a used head and crossed our fingers. I didn't use high temp rtv, which probably killed it for us:
https://www.youtube.com/watch?v=1BTTur7Fk6k
Make sure you have it correctly started each time until you break through and most of the shavings are gone.
06-15-2017, 11:30 PM
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
06-15-2017, 11:51 PM
Originally Posted by Cree
X2 on timesert. I had to do it. Bought kit from Amazon. Research I did, it's perfered over helicoil. Just rig up a long tip on an air compressor to blow out the aluminum shavings from the head. I did mine last year. No issues.
Sent from my SM-G920I using Tapatalk
06-15-2017, 11:57 PM
This is the kit I bought. Had very complete instructions as well.
06-16-2017, 12:00 AM
Use a Time-sert. Helicoil isn't an appropriate solution for this problem. Do not use an air compressor to clean out the shavings, use a shop vac so you don't blow junk into the cylinder.
06-16-2017, 10:14 AM
Real Name: Mitch
Real Name: Mitch
**** me dude, $200? Jesus christ... Worth it I suppose
What does this mean?
06-16-2017, 10:23 AM
Yes $200 is too much. I did this on mine a year ago, 20K miles no problems. Air is fine for blowing it out, a shop vac isn't strong enough to get down in there and remove everything. I used WD40 after I was done, and it smoked a while. This is what I used.
https://www.summitracing.com/parts/l...FVCCfgodD18LfQ
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
06-16-2017, 11:12 AM
Blow out is a major issue on some vehicles. Its recommended when doing any spark plug job to blow out the spark plug holes before removing any plugs so debris does not blow the plug out. But in your situation it was most likely fatigued aluminum threads from being over tq'ed during replacement of plugs and or not using an anti seize.
Like stated above you can use a heli coil. I always like to try and put that pistion at top dead center so less space for debris to fall and not as tough to blow out.
On a side not I have seen some Mitsubishi heads have heli coils all over. Few in the spark plug holes, few in the valve cover holes and many in the exhaust manifold holes. They are held up pretty good other than the exhaust manifold ones because they were under very high heat with turbos pushing 30+psi and that manifold is heavy as shit with a big turbo hanging off of it.
GOOD LUCK!!
06-16-2017, 11:26 AM
Real Name: Ron
Real Name: Ron
Just as a note, Continental aircraft engines in years past came from the factory with helicoils in the spark plug holes. Not particularly high compression ratios or cylinder pressures, either. I think it was just a way to improve reliability in the aluminum heads.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
06-16-2017, 11:51 AM
Real Name: 3 Bears
Real Name: 3 Bears
agree put piston at top, I used the leslie kit listed above and did this on a bmw 4 cylinder car. I used a shop vac with a small hose on it that fit into the cylinder to suck out the crap
06-16-2017, 12:34 PM
Real Name: Mitch
Real Name: Mitch
I ordered the time-cert. I can't find a bad review anywhere and I need to get this turd on the road by Monday morning. Or get my 240sx road-worthy....
06-16-2017, 01:11 PM
take your time, and dip the tap into grease each time. remove and clean the shavings often. that should prevent most of the chips from getting into the cylinder. the tiny ones that do(if any) get it will either be burned up, or ejected out the exhaust.
I did this on my 22RE about 10 years ago. it was my daily driver up until 3 years ago. its been fine ever since.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
06-16-2017, 02:03 PM
i used this. o'reilly's less than 30 bucks
98 Limited, DD with Sway Away coilovers, Camburg uniball uppers, OME 891's w/ Bilstein 5100's in back, 285 BFG, KO2, Factory elocker. custom sliders
97 LX450 is the fun toy
