10-18-2018, 04:20 PM
#31
Originally Posted by stecow
Sorry to revive an older thread. I just changed my manual trans oil and when I undid the fill plug about 3/4 of a quart of oil flowed out and then stopped, I drained it and filled the transmission through the fill plug till it started to over flow out the fill plug. I had the 4Runner parked on level ground too. So was my trans overfilled or did I under fill it? Am I just overly paranoid?
My question comes because everybody just says to fill the trans till oil starts to come out the fill plug and you're good, so when I first opened the drain plug no oil should've come out however there was quite a bit that did. Hopefully question this makes sense
No oil, or very little oil should come out the fill plug when parked level.
I say a little oil as some people put a bit more in for some reason.
If you drained it using the drain plug and then filled it till oil just started to come out the fill plug you're good to go.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
10-18-2018, 10:02 PM
#32
Thanks, I figured it would be okay, but just wanted to be double sure
10-19-2018, 12:08 AM
#33
Real Name: Keith
Real Name: Keith
It is a long established tradition, in shops as well as the shade tree realm, to goose the pump at the last few seconds when filling and then quickly screw in the filler plug, thereby getting "a little more in." That 'little more' probably amounts to a couple of tablespoonsful at most, but it's definitely a thing folks do.
Also, if your trans is warmed up when you drain it, the oil will have slightly expanded and a little more might come out when undoing the filler plug.
06-26-2019, 09:38 AM
#34
Originally Posted by eanema
One of the first things I did when I bought my '98 was change the diffs/trans fluid. I put Redline MT-90 in, and I did find shifting was a bit easier/less clunky but this is hardly scientific. I had only driven the thing for a few weeks before I changed it out. I would definitely be interested in seeing some sort of comparison, but that hard to come by.
To the OP, 4runner.org has gone up and down like a yo-yo over the past few years. I assume it's cause people like me read the site and don't donate to the hosting costs... But after the first time I noticed it went down I ripped the entire site. I attached a PDF print out of the write up your looking for.
So glad I found this thread. Thanks for the PDF!
2000 4Runner 5-Speed 4x4 TRD Supercharged
06-26-2019, 10:31 AM
#35
Change that transmission fluid.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
07-31-2021, 08:23 PM
#36
Anyone link the crush washers for the manual transmission? I am wanting to buy.
12-14-2022, 02:05 AM
#37
what's the recommended interval for changing a 5spd manual's fluids in the diffs, transmission and gear box? thanks!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
12-14-2022, 02:18 PM
#38
Change the gear oil in the tranny, t-case, and diffs every 30k miles or so and you'll be good.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
12-14-2022, 02:23 PM
#39
appreciate the response. can i use the same gear oil for all of them or are different weights/types required?
Manual Transmission
12-14-2022, 03:33 PM
#40
You can, though I recommend using 75W-90 GL-4 oil for the transmission and 75W-90 GL-5 oil for the transfer case. Redline MT-90 is pretty popular for the transmission. Most GL-5 oils have reactive sulfers that can be harmful to brass found in the synchronizers of the transmission. Will it kill your transmission if you use GL-5 oil? Probably not, many people use it without issue. For the diff, the owners manual recommends 90W oil, which is not common, I use the same GL-5 75W-90 oil in both my transfer case and my diffs. Been doing that for years and my 4runner hasn't exploded yet.
12-14-2022, 03:46 PM
#41
much appreciated!
Manual Transmission
12-14-2022, 04:58 PM
#42
Real Name: N/A
Real Name: N/A
Another vote for Redline MT90, it just works. I'm sure any gear oil of correct viscosity would work. GL4 is better for transmissions (supposedly).
I put GL5 in my transfer case and had no problems. If you do all the diffs and TC fluids at once, get the giant bottle of gear oil. For the differential get the cheapest GL5 oil, it makes no difference.
1998 4runner 2.7 manual
