Old 07-06-2017, 09:10 PM #1
dhphamqc dhphamqc is offline
dhphamqc is on a distinguished road
5 speed r150f vs 4 speed a340f
So I have just finished the 4wd auto swap. What would be the advantage of having a manual aside from having a 5th gear and better mileage? I just bought this r150f and may consider swapping it in or selling it. Also, I am confident I can do this swap right.
dhphamqc is offline   Reply With QuoteReply With Quote
Old 07-06-2017, 09:19 PM #2
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
I think the auto is better for just about everything besides fun and maintenance- and even maintenance is questionable with clutch replacements.
The mileage difference is negligible between my '97 auto and '01 manual- everything being equal. Both got/get 15-16mpg calculated on the same tires. It's a little better than that, because I am traveling more than my ODO says with the 315s.
I did the manual swap because I like driving manuals, and I've always wanted to manual swap a 3rd gen- swapping one that was a little more of a challenge was icing on the cool-factor cake.
I know some will disagree, but- in general- I think the auto is better for off-road.
Strawberry milkshake shouldn't even really be a factor, because that's pretty easy to eliminate.
Even if I got 1mpg better, that's really still nothing IMO. My commute is only 30 miles each way though.
If your rig is 100% stock- including wheels and tires- I think the manual might shine a little more vs the auto in mpg numbers.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 07-06-2017, 11:48 PM #3
RIDEALL RIDEALL is offline
RIDEALL is on a distinguished road
I always want the one I do not currently drive.
Had a 5spd Tacoma for 11 years. Loved it, but lusted for an Auto a lot.
Now I have an Auto, and miss the 5spd.
In the mornings, after a long bike ride, exploring
= Auto.
Afternoons, spirited driving on road, higher speed desert stuff, feeling manly = 5spd.
When I was shopping for my 4Runner, was looking for a 5 spd, after driving a couple, not as huge of a difference some lead on in my opinion.
I notice more of a difference in the Tacomas for some reason.
Not really wrong choice.
Sand dunes and rock crawling is easier in an auto.
Ramble over!!
RIDEALL is offline   Reply With QuoteReply With Quote
Old 07-06-2017, 11:52 PM #4
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
I'd say manual is a lot more fun to drive. Definitely more challenging on trails. It's also cooler hahaa. Every time anyone looks inside my truck and go ,"whoa manual?" This can be arguable but I think manual is stronger then autos. And no pink milkshake to worry. Not really worried about replacing a clutch every 100k or more.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 07-06-2017, 11:56 PM #5
Just sell the manual. The autos are great 5 speed r150f vs 4 speed a340f5 speed r150f vs 4 speed a340f
Old 07-07-2017, 01:48 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I chose manual because I was buying a truck with 100,000 miles. Autos can fail without warning once they get up in miles. Manuals give warning noises long before failing. If I was buying brand new, I'd have no problem getting an auto.
Autos are easier on the drivetrain over rough country IMO.
pluton is offline   Reply With QuoteReply With Quote
Old 07-07-2017, 01:51 AM #7
Didn't you do a manual swap also ?
Old 07-07-2017, 09:37 AM #8
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
It's just personal preference for me - really enjoy the manual trans.
I will say there are some situations off roading where an automatic would probably be better. Sometimes 1000 rpm/lo/1st gear is still a bit too fast, and you either have to get busy with a 3 pedal dance and slip the clutch a little, or just go over something a little quicker than you'd otherwise want to. Being able to 2-pedal inch your way over something might be better, but the other 99.8% of the time makes up for that.
Just did a clutch replacement on mine at 213K miles.
JohnMc is offline   Reply With QuoteReply With Quote
96 R150F swap into 01 4Runner with blown A340F manesfesto 3rd gen T4Rs 11 10-22-2016 12:23 PM
Speed over-reporting speed with stock tires? dieck 5th gen T4Rs 19 06-05-2015 04:12 PM
4 speed automatic vs 5 speed ('04 > '05+) DaveK22 4th Gen T4Rs 31 02-07-2015 04:05 PM
My R150F (5-speed manual) transmission is hungry for gear oil? brocktice Classic T4Rs 1 11-28-2013 08:03 PM
RPM differences between 4 speed Auto and 5 speed standard? kenlam 3rd gen T4Rs 2 10-14-2005 09:32 AM
