Quote:
Originally Posted by d0nkeyxpunch
I did. It doesn't budge and also shouldn't they return back to center after driving around? Ive loosened all the brackets pertaining to the swaybar and still no luck.
I think he's suggesting that you remove it altogether.
Also, part of the reason you have lean and your rear sway bar may not be completely "centered" anymore is likely due to your panhard bar.
When you add lift to the rear, your panhard bar actually causes your entire rear axle to shift slightly to one side.
Although a 3" lift shouldn't make THAT big of a difference.
