Old 07-10-2017, 01:24 PM #1
d0nkeyxpunch's Avatar
d0nkeyxpunch d0nkeyxpunch is offline
d0nkeyxpunch is on a distinguished road
3" Lift Question - Swaybar and Driver side lean
I installed a 3" lift setup not too long ago, and now my rear swaybar is not centered and pushed over to passenger side. The rear endlink on passenger side is straight up and down, but the driverside endlink is angled inward.
Also, I'm still getting driver side lean. Is it possible it's because of the rear swaybar? I'm 0.5" lower on the driver side. Everything was purchased new except for LC springs which had 146k miles.
Fronts: Wheeler T1 3" lift springs on Tundra Bilstein 5100 (bottom notch)
Rears: LC 8 wraps with Monroe Shocks for LC. Taller spring on driver side.
d0nkeyxpunch is offline   Reply With QuoteReply With Quote
Old 07-10-2017, 01:30 PM #2
Contact Lost Contact Lost is offline
Contact Lost is on a distinguished road
Are the springs clocked and seated correctly on the perches on both sides? Almost sounds like one could be clocked just that little bit differently changing the ride height. I am not sure how that would effect the sway bar side to side fitment though.
As a side note, what sway bar end links are you uusing?
Good luck!
Contact Lost is offline   Reply With QuoteReply With Quote
Old 07-10-2017, 01:45 PM #3
Yeah, the springs are seated properly on both sides. I'm running factory endlinks.
Old 07-10-2017, 01:52 PM #4
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Install a toytec front trim spacer on the driver side. This may fix the lean. I also had to add a 10mm ome trim spacer in the driver rear to get more level.
JayRolla is offline   Reply With QuoteReply With Quote
Old 07-10-2017, 02:17 PM #5
ajordan1975's Avatar
ajordan1975 ajordan1975 is offline
ajordan1975 is on a distinguished road
pull the sway bar.
98 Limited, DD with Sway Away coilovers, Camburg uniball uppers, OME 891's w/ Bilstein 5100's in back, 285 BFG, KO2, Factory elocker. custom sliders
97 LX450 is the fun toy
ajordan1975 is offline   Reply With QuoteReply With Quote
Old 07-10-2017, 02:53 PM #6
Originally Posted by ajordan1975 View Post
pull the sway bar.
I did. It doesn't budge and also shouldn't they return back to center after driving around? Ive loosened all the brackets pertaining to the swaybar and still no luck.
Old 07-10-2017, 02:59 PM #7
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
I think he's suggesting that you remove it altogether.
Also, part of the reason you have lean and your rear sway bar may not be completely "centered" anymore is likely due to your panhard bar.
When you add lift to the rear, your panhard bar actually causes your entire rear axle to shift slightly to one side.
Although a 3" lift shouldn't make THAT big of a difference.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 07-11-2017, 02:20 PM #8
duh! sorry.
i meant as in removing it completely.
also get an adjustable panhard bar.
Does your 4Runner lean on the Driver Side TOYSTRY 5th gen T4Rs 91 10-02-2019 08:46 AM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
Driver's side lean and lift Rancid13 4th Gen T4Rs 8 04-08-2014 08:07 AM
Best Driver's Side Lean Correction Spacer for use with Toytec Ultimate Lift? EdmundGTP 4th Gen T4Rs 11 06-25-2013 09:22 PM
