Originally Posted by loafer
2000 SR5-Sport I wanted to use the 231 mm tundra rotors and calipers. Ok here is the question . what year tundra 2001 or do i need a 2002.??Next question will I need to remove material from the back of a 16 inch 5 spoke OE wheel ?? I will be installing Mastercraft Coursers AXT onto a new set of wheels these will be ATX series AX-201 black lip and bronze centers, these wheels have a zero center and a 4 1/2" back space
I did mine last summer on my 01 sr5, and have the 5 spoke wheels. The year tundra doesn't matter it's the same brakes, think I told them 02 at Napa , and I never had rubbing from my wheels, it's close , however , some wheels mite have a little more material back there then others that could require some grinding :/ You will need to cut some of the dust cover for the bigger caliber. (That was much easier with a cutting wheel ) You should replace the brakes lines too and there is a bunch of posts on this subject.
Good luck
