10-19-2018, 08:12 AM
#226
Official Vendor
Official Vendor
Originally Posted by TonyB66
My apologies if I missed it earlier, but how far down from the sheet metal floor above does the tank or its support hang? Or, if easier, how much further down from the frame rails? Looks to be just a couple inches...
EDIT/ADD: If this photo above is with the tank in-place, that answers my question!
Tony - that's the tank in-place, but keep in mind that without a 1" BL you'll need to clearance the body crossmember above it (there's plenty of material to clearance there) - however, it won't change the relation of the tank to the frame rails, it will sit as shown in either case.
Hope that helps!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
10-19-2018, 11:11 AM
#227
Hope that helps!
I should know this answer by now since I have had my parts for this a while, but cyclocross racing takes over all my fall weekends.
With a 2" BL how hard would it be to tuck the tank up farther?
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
10-19-2018, 01:13 PM
#228
Official Vendor
Official Vendor
hmm.. - if you flattened the pinch welds on either end and ran totally flat lower straps, you could probably go up another inch with it? it's certainly worth considering in your situation.
keith
eimkeith.com
10-19-2018, 01:17 PM
#229
May not be worth it looking at the pics. It doesn't look like there is that much hanging down past the frame rails.
10-19-2018, 01:37 PM
#230
Official Vendor
Official Vendor
well, there's also something to be said about keeping the weight of the fuel lower - if even by an inch!
keith
eimkeith.com
10-19-2018, 04:04 PM
#231
According to some I am already on the fast track to death because I installed a body lift.
10-19-2018, 11:16 PM
#232
Official Vendor
Official Vendor
yeah, well, they don't understand the usable range of motion of IFS, I guess... ;)
keith
eimkeith.com
11-23-2018, 08:16 PM
#233
Real Name: Addison
Real Name: Addison
Well done. So cool to see all of these small, innovative, parts coming to life that address the flaws of the 4Runner chassis for our applications. Love the simplicity and precise design of your parts.
I gotta say it.... 4th gen next ?!?!?!
11-24-2018, 09:44 AM
#234
Official Vendor
Official Vendor
Yeah, I'm planning some more 4th gen love. PCK for the 4th gen turned out really well!
keith
eimkeith.com
11-24-2018, 11:49 AM
#235
noticed a few in the thread are from good ole California. Is the f150 tank swap easy to get smog legal?
11-24-2018, 04:16 PM
#236
Real Name: Addison
Real Name: Addison
Ordering my PCK right now! Thanks for the sale!
11-26-2018, 03:09 PM
#237
No smog guy is going to check where your fuel tank is located. As long as it doesn't throw any OBD codes, it shouldn't be an issue. I bet you could even run dual tanks and it wouldn't throw codes with the right venting setup.
I don't think there is any reasonable way to make it truly legal though...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-26-2018, 05:43 PM
#238
Yeah, I was thinking that as well. With it looking like a factory fuel tank and not something that screams fuel cell I’m sure it’s not to big a deal. Also connected to the factory filler location would make it less
Suspect too.
01-05-2019, 01:46 AM
#239
My first post here, but wanted to get in on the brackets if possible. Joined so I could build my first 4Runner Money pit. 3rd Gen SAS 3/4 Linked. Looks like the fuel tank conversion is a must in the build.
01-05-2019, 11:01 AM
#240
Official Vendor
Official Vendor
absolutely! you can order a set here: Fuel Tank Relocation Mounts – eimkeith.com
keith
eimkeith.com
