06-04-2019, 12:18 PM
#346
Official Vendor
Official Vendor
Fuel Tank Relocation (and new Rear Bumper design)
Originally Posted by Dezerts10
Does your bumper design have a receiver built in?
The bumper has provisions for a receiver, but a third-party receiver (like you'd buy from e-trailer or similar) will not be included in the bumper purchase for overall cost, shipping, and liability reasons.
Check it out:
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
06-04-2019, 12:57 PM
#347
Real Name: Addison
Real Name: Addison
Maybe I missed it somewhere, but do you have a link for the specific lights you spec'd the rear holes for?
@ eimkeith
06-04-2019, 01:30 PM
#348
Official Vendor
Official Vendor
@ eimkeith
Oh sorry, hadn’t mentioned that yet - they’re for Rigid Industries IGNITE back up light kit - 20641.
- to be mounted behind the bumper.
keith
eimkeith.com
06-05-2019, 10:37 AM
#349
Originally Posted by eimkeith
The bumper has provisions for a receiver, but a third-party receiver (like you'd buy from e-trailer or similar) will not be included in the bumper purchase for overall cost, shipping, and liability.
So there will be structure there for like a 6” or so receiver to be welded in it looks like? I actually have one waiting then. I was going to build a front bumper with a hidden receiver and I bought the little 6” long receiver from e-trailer and never used it. I also have some 2.5” square .250” wall material in my metal rack that is the same Inside dimensions as a receiver is.
06-05-2019, 10:46 AM
#350
Official Vendor
Official Vendor
Perfect! Here’s how I’m doing it on mine:
keith
eimkeith.com
06-05-2019, 01:37 PM
#351
Real Name: Patrick
Real Name: Patrick
Is the only additional piece needed for it to hitch compatible the receiver, or is there additional support that will need to be added? I probably missed it, but will the bumpers be pre-bent just requiring welding?
06-05-2019, 01:58 PM
#352
Official Vendor
Official Vendor
To be hitch-compatible you'll need to provide a ~40.5" length of 2x2" tubing (welds in between the supplied bumper mounts) and a short receiver.
That's correct. There will be 5 pre-bent brackets, 2 recovery points, and 3 pre-bent bumper parts in the bumper kit. (and some hardware)
You'll need to provide the OEM running board cover for the top of the step (this covers the access holes and finishes off the top of the bumper - I'll give measurements for how to trim it to fit) and the aux reverse lights (if you choose to run them)
Also Note: - The bumper requires the rear cross member from my fuel tank relocation bracket kit as its basis, so if you don't have one of my kits you'll need to add a crossmember to the order.
- It also requires a 1" body lift, and I strongly advise the use of poly body bushings on the rear body mounts to minimize flex & potential body contact when wheeling.
- And, you will need to cut out the pinch weld in the rear of the wheel well on each side for clearance, as the bumper is designed to provide full articulation with 35" tires.
keith
eimkeith.com
06-08-2019, 01:01 PM
#353
To be hitch-compatible you'll need to provide a ~40.5" length of 2x2" tubing (welds in between the supplied bumper mounts)and short receiver
The 40.5” tube runs left to right and the receiver will butt up against it and also need to be welded at the face of the bumper I assume?
06-08-2019, 01:38 PM
#354
Official Vendor
Official Vendor
Receiver goes over the top of it (post 350). The bottom of the receiver is notched to reduce the overall height
Sent from my iPhone using Tapatalk Pro
keith
eimkeith.com
06-10-2019, 08:59 AM
#355
Official Vendor
Official Vendor
got of quick video of
@ Coward
spinning a 315 at full stuff on the factory bump with the prototype bumper installed:
(you can hear the tread clicking on the untrimmed SR5 flare)
keith
eimkeith.com
07-20-2019, 02:30 AM
#356
Official Vendor
Official Vendor
I'm now taking pre-orders, guys - check it out.
keith
eimkeith.com
07-20-2019, 10:47 AM
#357
Awesome Keith! Congrats on getting these bumpers to the masses!
I’ve always planned to custom design and build my own rear bumper, but I’ve been leaning more and more toward buying one recently. There is so much thought and purpose behind your design I think anyone would be a fool to choose something else.
When you get your first run of non-BL bumpers with the option to line up with the limited flares, you can count on me to purchase one!
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
07-20-2019, 11:00 AM
#358
Official Vendor
Official Vendor
Thanks for the kind words!
I'm actually releasing a non-BL mount kit as an add-on later in the year. The flare extensions will be add-ons as well. This allows me to maintain the same base bumper for all scenarios and keep the price down for you guys.
keith
eimkeith.com
07-20-2019, 11:32 AM
#359
Ha, you’re making this really tempting to pre-order now...
07-20-2019, 12:58 PM
#360
Sicmods Keith!!!! Just gotta save up some funds so I can get the f150 fuel tank relocation and bumper together !!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
