03-23-2020, 01:31 PM
#481
Real Name: Samuel
Real Name: Samuel
Not sure if I missed reading it or if people haven’t posted about it so I’ll ask. For the people who have done this how did you plumb the filler neck vent line? Or did you guys buy a universal internally vented filler neck? I was gonna modify the OE one and weld a bung on the tank and just thread a barb fitting in. I’ve already welded on the Toyota flanges on the tank and everything.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
03-23-2020, 03:25 PM
#482
I used a Russell -8 tank bung, drilled an extra hole into the tank, and tightened it up through the pump opening. I then cut and teed into the factory vent line on the filler neck as high up as was feasible with 1/2" fuel line to prevent liquid phase gas from settling in it and plugging it. Having dealt with a lot of the internal vent setup that ford has used forever I hate it. I find that separate is far more serviceable. I was also able to leave the line long along with my supply, return, and electrical lines so I can drop the tank to the ground with everything except the filler neck still connected for service.
04-01-2020, 08:27 AM
#483
Official Vendor
Official Vendor
Fuel Tank Relocation (and new Rear Bumper design)
Just a heads up if anyone was considering a bumper..
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
04-08-2020, 06:37 PM
#484
For those that have done the tank swap, what did you do with your exhaust tail pipe? I'm trying to figure out how to do mine (keeping in mind, I've gotta keep mine CA smog legal and I don't have a body lift).
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
04-08-2020, 11:18 PM
#485
Without the body lift it’s difficult. Only option is to go out before the rear tire between the frame and lower link. I’ve done it in the past. Depending on your muffler it can significantly increase the sound in the cab though.
04-08-2020, 11:28 PM
#486
Real Name: Samuel
Real Name: Samuel
I just cut the flange off the back of the muffler and clamped a turn down pipe to it. I don’t have a body lift so that was the only thing I could think of doing. Not much help sorry
04-09-2020, 01:22 AM
#487
Like this?
This might be my only reasonable option. Is your exhaust any louder? Is excess heat/fumes under the rear passenger seat a concern?
Edit: Photo should show now
04-09-2020, 01:38 AM
#488
Real Name: Samuel
Real Name: Samuel
Originally Posted by Team_Jake
Like this?
Sorry the picture doesn’t work so I can’t see. The flange coming off the muffler that connects to the tailpipe I cut. I cut it so that it was perfectly horizontal. Slid a turndown pipe over it and clamped it. I have not had the chance to hear it I’m still working on some engine stuff. My 98 beater truck has the same setup though. I did not notice any sound difference at all. On my 99 that I’m working on right now the catalytic was stolen off of it and instead I put a resonator pipe in. I have no idea what it’s gonna sound like or if it will be good or bad. Can’t wait to find out lol. I’ll get back to you on if there is any heat or fume issues but I do not think there will be unless your idling in one spot for long period of time
04-09-2020, 02:00 AM
#489
Real Name: Samuel
Real Name: Samuel
Like this?
Yep exactly like that!
04-09-2020, 03:14 AM
#490
I’m of the belief you’ve gotta get it out from under the truck but that’s just from personal experiences. One is that if you roll down the rear window at all it’s all gonna roll back into the cab. And the other is that that heat will be carried back over the rear axle and heat the rear tank. Yes it will be highly dissipated while in motion but over a long pull it will affect things. Like excess vapor loss from the rear tank or loading the canister especially on the hot summer asphalt.
As an example, once had a friend cut off the exhaust on a caged truck with no bed, granted he had no down turn, but it heated the fuel cell enough to literally boil the gas out the vent and all over my windshield while climbing the highway up to big bear.
Just something to keep in mind.
04-09-2020, 07:22 AM
#491
Official Vendor
Official Vendor
The tank is cheated over to the left so that there is more room on the right to snake the exhaust past its front right corner if needed (over the crossmember, like stock). I'd definitely wrap it where it passes by the front corner of the tank though.
Additionally, the inside fender wall there has a very portion of single-layer steel that does not penetrate into the cabin - I'm going over the frame and through that on my install to get the pipe behind the tire. A body lift definitely helps here, but there's no reason to stick with a 2.5" pipe back there, either IMO.
keith
eimkeith.com
04-09-2020, 03:46 PM
#492
Real Name: Samuel
Real Name: Samuel
I had some more time to take a look at it this afternoon. For now I’m gonna leave the turndown pipe on the muffler and just see how it goes. If there’s too much of a fume smell I’ll change it. Looking at it though if you cut the flange off like I did and use an adapter to reduce the tail pipe down to a smaller diameter pipe it wouldn’t be too hard to make a custom tailpipe that would snake by the gas tank. Without a body lift I don’t think you’d be able to run it above the frame even after trimming some of the body.
04-09-2020, 07:00 PM
#493
For smog purposes, you can do anything you want after the cats... So no worries about smog issues. Make sure the outlet is easy to get to if you want your smog tech to be happy with you.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-12-2020, 01:44 PM
#494
Real Name: Samuel
Real Name: Samuel
Anybody have issues wiring the ford fuel pump to the Toyota harness. When I turn the key to the On position I don’t hear it running. Cranking it to start I can hear it running. I must have something backwards. I though I had it right when I spliced the wires. Anybody have a diagram on what they did? Thanks guys
04-13-2020, 08:40 AM
#495
Real Name: Patrick
Real Name: Patrick
I may be wrong but I don't think toyota sends a prime signal to the fuel pump. I think it only starts pumping when you try to start.
