06-13-2018, 09:58 PM
#106
Official Vendor
Official Vendor
Originally Posted by theesotericone
LMAO.
In my trails thread I've stated 10 times that I do not want a body lift. It's easier to do duals with, it's easier to clearance 37's with, it's easier to flat belly. You get the idea. I never take the easy way. lol
You forgot: easier to keep maximum up-travel with, etc. ;)
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
06-14-2018, 12:26 AM
#107
LMAO.
What about an ascenseur de corps
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
06-15-2018, 01:28 AM
#108
Real Name: Sam
Real Name: Sam
I will definitely be interested in one when you have pricing
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
07-09-2018, 12:29 PM
#109
Official Vendor
Official Vendor
looks like we're going to be in the $130 range (plus shipping) if I can get 10 or more folks onboard.
does that work for you guys?
this will be for the big rear mount cross member and the 2 front mounts. these will be prototypes, but I'm pretty confident on the design (I've checked full flex clearance on the front mounts with a PCK, even!)
for install on trucks without a BL you'll need to clearance the support rib above the tank (which is more than an inch tall, so you'll still have some vertical sides to the rib)
you'll need to cut out the spare tire crossmember also. (duh.)
- let me know, and I'll pull the trigger on it.
Originally Posted by eimkeith
I started with the tank mounting; working on some front brackets and rear crossmember (crossmember taken virtually directly from the Ford frame design)
keep in mind that unlike Assburns, I'm working with a one inch BL (both for tank mounting and for flat belly in the future):
Just a quick update/FYI - I sent my files for F150 fuel tank rear crossmember & front mounting brackets out for quoting today; these are a weld-on solution for the DIY-type, similar to my PCK stuff.
When the quote comes back I'll let you guys know the pricing, and if there is interest we'll get some of these made!
Originally Posted by rkntoy
Mark me down as interested. Thanks for all your efforts on this (and the PCK).
I'm interested for sure. I've been keeping it on the back burner till the gears/lockers/dual cases where done. Did you ever look further into duals?
keith
eimkeith.com
07-09-2018, 02:56 PM
#110
Real Name: C8H18 Mike
Interested
Sent from my Pixel XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
07-09-2018, 04:39 PM
#111
In like Flynn.
07-09-2018, 07:35 PM
#112
Pull it!
07-09-2018, 10:21 PM
#113
Official Vendor
Official Vendor
well, let's see who's really in first - let me know if you want to be added (or removed) from the list:
eimkeith
@rkntoy
@theesotericone
@Rockdawg84
@octanejunkie
@Tyler_James_Inc
- and I'm pretty sure my mention tags are screwed up... :|
keith
eimkeith.com
07-09-2018, 10:54 PM
#114
I'd love to see a pic or sketch of the kit and an equipment list with recommended sources to aquire said parts.
I'm not gonna do a body lift so I'm good with cutting shit out to make it fit.
Then I need
@ AssBurns
rear bumper plans!
07-09-2018, 11:49 PM
#115
I'm so tempted, but I'm going to force myself to hold off for several reasons.
I know this is to SWAP tanks, not to have an AUX tank. I would want to have an AUX tank and then just flip a switch to transfer fuel from it to the main tank. Has anyone come across that setup and how they did it? Two main questions would be how to fill the second tank and how to run the line into the main tank...
Overall, I think I'm done trying to get things to Alaska. It's not worth me throwing temper tantrums every time I try. LOL
To the two guys who did this on here... Great job!! Threads like this makes projects so tempting to do!
07-10-2018, 06:59 AM
#117
Official Vendor
Official Vendor
Photos of the front mounts and a sample portion of the rear crossmember that shows how it accommodates the factory Ford tank straps are shown in here.
If there is enough interest to get these mounts made, I'll continue to look into the filler neck and wiring solutions to make a more complete DIY 'install kit.'
FWIW, I'm using the Spectra F1G that I got on Amazon in my truck.. (I haven't ordered the pump/sender yet because I'm still investigating solutions to the stock fuel gauge issue - I'm determined to use the factory gauge.)
Just to clarify; this isn't an 'install' kit (it's possible that it will be in the future) - it is a mounting kit: 2 front weld in brackets and a rear cross member that will allow you to mount a Ford tank between the frame rails and under the floor in the rear of the 3rd Gen 4Runner.
It doesn't prohibit using the Ford tank as an aux tank, and it doesn't require removal of the factory tank; it's simply a mounting solution for a Ford rear tank.
keith
eimkeith.com
07-10-2018, 07:20 AM
#118
Official Vendor
Official Vendor
OK, so our 'official' list so far is:
- eimkeith
- rkntoy
- Rockdawg84
- Tyler_James_Inc
- octanejunkie
(I know a couple of you other guys are interested - let me know if you're in.)
keith
eimkeith.com
07-10-2018, 08:45 AM
#119
- eimkeith
- rkntoy
- Rockdawg84
- Tyler_James_Inc
I'm in and would love to see/develop an option as a second, aux tank, using an in-tank fuel pump as a manual transfer pump, with separate gauge
07-10-2018, 09:27 AM
#120
Official Vendor
Official Vendor
oops - I inadvertently dropped you off (which is why I shouldn't internet before coffee or after beer)
list amended!
keith
eimkeith.com
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
