10-14-2019, 12:14 PM
#421
Real Name: Tyler
Real Name: Tyler
Originally Posted by eimkeith
Well, the bumper clears 37s.
Painted pics tonight. Paints still out curing..... Also not seeing the picture
2000 4Runner:Kings, 37s, lockers 2018 TRD OR:stock and staying that way
10-14-2019, 03:39 PM
#422
Picture isn’t working
How’s progress on the no BL bumper coming?
10-14-2019, 03:47 PM
#423
Real Name: Tyler
Real Name: Tyler
Since its not just me I'll post it. Its my truck anyways
Untitled by Tyler Carvell, on Flickr
10-14-2019, 04:53 PM
#424
Originally Posted by TCMach
What do you have done to your truck on the rear? I don’t think I’d ever go 37” tires but probably will bump up to 35” tires from my 33” tires I currently have. I also run a 17” wheel.
10-14-2019, 05:27 PM
#425
Real Name: Tyler
Real Name: Tyler
Honestly not much. Toytec boss shocks, 861s, extended bump stops. Its all pretty standard. Rear pinch welds are trimmed on the front and rear of the wheel well. If you keep you backspacing down (4.25-4.5") you'll tuck it inside the top lip of the body with minor massaging necessary. It does mean I run spacers up front to get the track width I want, but I'm fine with that if it means I'm not reworking a whole bunch of sheet metal and losing my flares.
10-14-2019, 06:08 PM
#426
Official Vendor
Official Vendor
Yeah, I just learned something about cross-posting photos. Should work now, I think?
Well the bumper is the same, there is an additional non-BL install kit in development. I've got the main mounts sorted, working on the frame extensions currently.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
10-16-2019, 12:23 PM
#427
Real Name: Tyler
Real Name: Tyler
Done and Painted. Now to beat it up... and find a running board cover i can use
10-16-2019, 12:48 PM
#428
Looks like somebody needs a panhard correction kit!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-16-2019, 01:50 PM
#429
Real Name: Tyler
Real Name: Tyler
Bought one with it. And gas tank brackets. I went all in. However my lower panhard bolt is seized in the sleeve..... So project for another day!
10-16-2019, 02:29 PM
#430
Pictures of that bumper never get old. Looks great.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
10-24-2019, 12:35 PM
#431
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
10-24-2019, 02:47 PM
#432
Official Vendor
Official Vendor
That last shot kills me.
keith
eimkeith.com
11-14-2019, 09:28 PM
#433
Changing the topic back to Fuel Tank Relocation.
I haven't seen this mentioned anywhere...I came across a gadget called Fuel-Link by Classic Instruments which looks like it can calibrate any sending unit input. (For those of us who want to use the OEM gas gauge and don't want to modify the sending unit in the Ford tank).
Summit Racing Link
It isn't cheap ($122)...but it looks easy to set up and is probably more accurate than my fuel tank sending unit/reader is now . Anyone aware of other calibration gadgets out there?
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
11-15-2019, 08:27 AM
#434
Official Vendor
Official Vendor
Summit Racing Link
wow - that looks really promising.
keith
eimkeith.com
11-15-2019, 11:09 AM
#435
Real Name: Patrick
Real Name: Patrick
It's not cheap, but it's a better solution IMO than modifying the ford tank for the toyota sender then having to modify the sender to read correctly.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
