Old 08-01-2017, 02:13 AM #1
PantherExpeditions
Guest
Posts: n/a
PantherExpeditions
Guest
Posts: n/a
Differential and Transfer Case Breather Mod
Hey all,
I have searched high and low for this questions, but there is a lack of information. I have a 5-speed 1999 and want to run a breather extension from the transmission and transfer case. Any information about location of stock breathers would be appreciated! My truck only has the extended front diff breather stock. Thanks.
  Reply With QuoteReply With Quote
Old 08-01-2017, 02:08 PM #2
Originally Posted by PantherExpeditions View Post
Hey all,
The stock breathers for the transmission and transfer case are right at the top of each. They are around the same height as the stock front diff breather. How high do you want to bring them?
This is the best I got (I have an auto, so I can only show you the transfer case portion...):
The breather is the small circle next to the front 4-bolt plate in front of the transfer case shifter. There is a vacuum line from the transfer case itself to the transfer case adapter that you can barely see on the left side. The auto trans breather goes from the top of the case with a pipe or hose (depends on year) that goes up the bellhousing a bit.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-01-2017, 09:14 PM #3
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Charlie,
is that from a multi-mode TC? Mine has the transfer lever located where that blank plate beside the breather is.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-02-2017, 03:26 PM #4
Originally Posted by HiluxSurf SSR-G View Post
Charlie,
No, standard j-shift. All of the US delivered 4Runners are top-shift, even the multi-mode ones... except for maybe the 4-cylinder manual trans trucks, I think?
If you have the diesel (I think you do?), then your case is a front-shift, due to the different location of the transmission and engine on that setup.
Old 08-02-2017, 06:00 PM #5
I see, thanks for that. Yes, mine is a diesel.
Old 09-03-2017, 02:08 PM #6
bugman-74's Avatar
bugman-74 bugman-74 is offline
bugman-74 is on a distinguished road
bugman-74's Avatar
Tcase/Trans Breather Extension?
bugman-74 is offline   Reply With QuoteReply With Quote
Old 01-11-2023, 12:06 PM #7
psea17 psea17 is offline
psea17 will become famous soon enough
did you ever come up with a solution to extend your '99's breathers? thx!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Differential and transfer case oil change 6T9CUDA 3rd gen T4Rs 10 07-02-2022 11:28 AM
Transfer case breather Gerdo 3rd gen T4Rs 1 12-02-2012 04:19 PM
Transfer Case Breather Foureigner 3rd gen T4Rs 5 10-17-2009 10:34 AM
Missing breather for axle/transfer case gapboi210 3rd gen T4Rs 0 11-25-2006 11:01 AM
Transfer case & Differential fluids? msanta Maintenance/Detailing 8 04-18-2005 03:20 PM
