07-28-2017, 08:31 PM
#16
Real Name: Jeremiah
Real Name: Jeremiah
Originally Posted by Mr.Rick
DO NOT WELD ON THE FILLER NECK WHILE IT'S ATTACHED TO THE FUEL TANK!!!
This killed me haha! I appreciate that you are cautious enough to put this warning out but it scares the hell out of me that this even needed to be said.....
Originally Posted by theesotericone
LMAO. That made my night man. I was wondering whether you'd hook to the filler neck or top of tank.
Yes, unfortunately people do dumber stuff on a daily basis. Everything "has" to have a warning label.
07-28-2017, 08:54 PM
#17
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
07-28-2017, 09:49 PM
#18
Real Name: Jeremiah
Real Name: Jeremiah
Originally Posted by rkntoy
I want to see where the filler goes. Have a Suzuki Sidekick tank that is waiting for a filler solution I like - and is affordable.
I have a basic idea, but I need to get the tank in it's exact spot before I can mock it up.
Originally Posted by Sean K.
Specs on the pump? YMM? How many PSI?
Nevermind....found it: https://www.summitracing.com/parts/crt-p4600hp
I know you're just using this as a transfer pump but 4.5-8 psi is pretty low for an EFI system like Toyota uses. Again, shouldn't matter since you're only transferring fuel, but why did you pick that particular pump if you don't mind me asking?
Good question. The psi of the pump doesn't matter because it's just transferring the fuel to the main tank. This pump is "free flow" rated at 100 gallons per hour, that means I can pump all 16 gallons of auxiliary fuel in less than 10 minutes. I've used variations of this pump for years to transfer fuel in the shops I have worked for and I've never seen a failure, they are super reliable.
Originally Posted by phattyduck
What's the plan for air return to the aux tank to offset the fuel emptying to the main tank? You should probably be able to tee off the tank vent, but then you have to have a sealed aux tank to keep evap happy (though, I suppose that is obvious).
That's where things get tricky. To transfer fuel between the two tanks (without removing both gas caps) there has to be a shared vent hose between the two tanks to equalize the pressure. But, when I'm driving around with the aux tank empty there will be an extra 16+ gallons of air volume in the fuel system, which will probably trigger evap codes. So in addition to the fuel on/off valve I also have to install a on/off valve for the vent hose, that will completely isolate the aux tank from the main tank while not transferring fuel. I plan on mounting both valves next to each other for quick and easy operation.
07-28-2017, 10:22 PM
#19
Real Name: Jeremiah
Real Name: Jeremiah
Here is the start of the upper supports for the aux fuel tank, it will be sandwiched like a Ford tank with HD straps below. You can also see the bracket for the fuel pump, I mounted it behind the tire to keep it protected from dropping off ledges and angry rocks.
07-28-2017, 11:43 PM
#20
Any plans for a skid plate or something to protect the tank from rocks, branches, etc.?
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
07-29-2017, 12:18 AM
#21
Thanks for the info. Carter has a good reputation for quality pumps.....I was just curious about the PSI.
07-29-2017, 09:53 PM
#22
Real Name: Jeremiah
Real Name: Jeremiah
I plan on having something, but I'm not sure what that will be yet. I really don't want a full 3/16" skid plate due to the extra weight. I'll figure something out, just need to get it in place first and go from there.
08-06-2017, 12:24 PM
#23
Real Name: Jeremiah
Real Name: Jeremiah
I got the second fuel tank support in place, so I was able to mock the tank in place and see how high I was able to get it. I was pleasantly surprised when I got it in place and took some measurements, it sets just a little over an inch below the frame rails. Once I get some real tank straps under it I should be right at an inch, you can't even see it when walking around the truck!
08-15-2017, 11:22 AM
#24
Any more thoughts on filler routing? I am about to give up on my aux tank idea as I cannot figure out a filler solution that I like.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
08-15-2017, 03:41 PM
#25
Real Name: Steven
Real Name: Steven
Why not buy a filler neck with a cap and have a separate filler neck for the aux tank? Like this.
http://www.tanksinc.com/index.cfm/pa...rod/prd510.htm
08-15-2017, 04:32 PM
#26
Yes, but where do you mount it.
08-15-2017, 07:53 PM
#27
Real Name: Steven
Real Name: Steven
@ rkntoy
Weld a tab on it and mount it to the same bolt that the factory filler neck bolts to. Should be pretty easy to do.
08-15-2017, 07:57 PM
#28
Official Vendor
Official Vendor
So the aux tank on my '74 F100 is done this way - fills through the wheel well!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
08-15-2017, 07:58 PM
#29
Official Vendor
Official Vendor
Why not modify the filler for a Y? fill both tanks with factory fill tube?
keith
eimkeith.com
08-15-2017, 09:41 PM
#30
@ AssBurns
- then where would it go? As this is for an aux tank I still need to fill my main tank.
@ eimkeith
- not a big fan of the wheelwell mount with all the dirt and mud kicking up there. Also it would end up being not much higher than the tank. The LC80 dual tank Y would be awesome but cheapest i found was $400. Living in Oregon a simple Y is a problem since the state says I am too dumb to fill my own gas tank without blowing up the gas station.
I should probably start my own thread and give
@ Dirtco
back his
