I just wanted to update everyone with additional information that can now be found on our
website, we appreciate all the questions. The first round of racks will be going out before the end of the month to everyone who ordered before August 11th. We apologize for the long lead time on these first racks as we are still ordering them in small batches. Our next goal is working on building up stock so we can get them out to you guys even faster.
PRODUCT INFORMATION:
Rack Dimensions: 91”L x 43-1/2”W x 6”T
Crossbar Dimensions: 1”Tx2”Wx43”L
MOUNTING — The roof rack mounts into the OEM roof rails with four 1/4” thick aluminum brackets that are 2” tall. This height is the perfect balance of keeping your weight as low as possible while still making it easy to mount things to the rack. The front of the rack rests on two adjustable mounts that allow you to set the amount of pressure you need.
CROSSBARS — The rack itself features six aluminum extrusion crossbars that can be adjusted forwards and back. When you combine the adjustability of the bars with the versatility of the t-slot channel built into each cross bar, it makes for an endless number of ways to mount your gear.*
HAND HOLDS — Built into the side plate of each rack are hand holds that make getting to the gear on your roof a breeze.*
TIE DOWNS — More important than just getting to you gear is securing it. The built in anchor points can be used to quickly secure things to the roof without hassle of hard mounting.*
FAIRING — The front fairing includes options for mounting a single row light bar or you can go with the full-size fairing if you wanna keep it simple. The fairing can be adjusted to varying heights, ensuring proper fitment on each vehicles. Fairings include rubber stripping to prevent vehicle damage.*
DETAILS
The roof rack DOES NOT ship assembled in order to reduce the cost of shipping.*
All racks come UNPAINTED and are bare aluminum. Aluminum will not rust in wet conditions, but we do recommend painting as the bare aluminum does get micro scratches and finger prints on the surface during the manufacturing process.
