Old 08-04-2017, 06:19 AM #1
humboldtrunner humboldtrunner is offline
humboldtrunner is on a distinguished road
cost to replace timing belt + water pump ?
Hello all , what is the approximate labor cost to have a shop do this work her in northern california and what is a fair price for all oem parts, timing belt thermostat, water pump etc. ? I have read the tutorials on doing the job and I could probably do it my self but I don't have a belt tensioner
humboldtrunner is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 07:24 AM #2
Killer Squirrel's Avatar
Killer Squirrel Killer Squirrel is offline
Killer Squirrel is on a distinguished road
From the research I have done, the best value for the parts is on eBay, look up seller aircabinman and he has several kits available. He will even make a custom kit for you if you don't need certain parts (for instance I didn't need the regular alternator belt or thermostat since I am supercharged). Can't help you on labor costs but the job really isn't all that bad. I don't have a belt tensioner either, you can just go by feel.
- 2000 4x4 Highlander SC
Killer Squirrel is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 08:08 AM #3
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
As mentioned above. Get the aircabinman kit from ebay, you will have all of the OEM parts you need at the best price around. Under $300.00
15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine & OE Manufacture Parts! | eBay
I'm not sure how much a shop will charge you in labor to install this in North Cal, but when I shopped around here in Canada it was around $500-$600 (CAD), but they also warned me that if the crank and cam seals needed replacement, then there would be a little bit more labor involved. So, maybe around $400 USD for labor?
Nothing ever came of it as I still have the kit in my Garage at the moment. I'm not gonna bother having it replaced until either the timing belt or water pump give out (or I just happen to have some extra cash to throw on the install.)
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 08:55 AM #4
Miketsi99 Miketsi99 is offline
Miketsi99 is on a distinguished road
Great Info, Thanks.
Miketsi99 is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 02:56 PM #5
nobb nobb is offline
nobb is on a distinguished road
Haven't checked recently but you can also take the parts list and piece it out on Amayama. Might be even cheaper than aircabinman's kit and you get the benefit of being able to customize the parts.
nobb is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 04:35 PM #6
Yoder68 Yoder68 is offline
Yoder68 is on a distinguished road
[QUOTE=humboldtrunner;2765933]Hello all , what is the approximate labor cost to have a shop do this work her in northern california and what is a fair price for all oem parts, timing belt thermostat, water pump etc. ? I have read the tutorials on doing the job and I could probably do it my self but I don't have a belt tensioner[/QUOTE
The belt tensioner is bolted to the block. It is a part that is generally replaced when you do the timing belt job. It's not a tool.
Does that make sense?
Also, the front crank seal is easy to replace once you have everything apart. It adds maybe 5 minutes to the job.
Yoder68 is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 04:43 PM #7
DionJ DionJ is offline
DionJ is on a distinguished road
5 hours labor for ccomplete kt with seals. Your mechanic charges x. The only one I trust is now $130. My kid is heading up to Humboldt for school, can you recommend anyone up there for maintenence?
DionJ is offline   Reply With QuoteReply With Quote
Old 08-12-2017, 09:59 PM #8
[QUOTE=Yoder68;2766359]
I was referring to a belt tensioner compressor tool that compresses the tensioner when replacing the belt
Old 08-12-2017, 10:07 PM #9
I've heard that Honest Engine and Franklin's Auto Service are good. They are both in Arcata
Old 08-12-2017, 10:45 PM #10
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
[QUOTE=humboldtrunner;2772906]
The kits come with a compressed tensioner so you don't need the tool.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 12:50 PM #11
animator's Avatar
animator animator is offline
animator is on a distinguished road
animator's Avatar
Originally Posted by verbutani View Post
I'll bet it doesn't take $500 in tools to to the job.
< / SERMON >
Especially if you rent them. The two biggest specialty tools you need are the spanner to hold the crank pulley while you tigthen/loosen the bolt, and a torque wrench that reads up to 250 lbs. I rented a torque wrench from my local Oreily Auto parts, since mine doesn't go that high.
Everything else can be done with a basic hand tool set.
2002 4runner Sport Edition
animator is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 01:49 PM #12
7echo 7echo is offline
7echo is on a distinguished road
About as far from NorCal as you can get but just for reference-
Well respected indie shop gets $950, dealer is at $1400, parts and labor.
'99 Limited, 4WD, elocker
7echo is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 02:23 PM #13
cstmg8's Avatar
cstmg8 cstmg8 is offline
cstmg8 is on a distinguished road
cstmg8's Avatar
[QUOTE=JRZEE2000TR4LTD;2772935]
This, otherwise take it off and stick it in a vice,or maybe compress it with a clamp on the engine, never tried that. It has a hole where you pin it down with an Alan wrench or nail or something untill installed.
Sent from my XT1585 using Tapatalk
cstmg8 is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 07:36 PM #14
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
$1400 at a Lexus dealer.
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 08-16-2017, 12:07 AM #15
111db 111db is offline
111db is on a distinguished road
If you don't need accessory belts, this kit is $180 with a bunch of OEM parts. I picked it up a few weeks ago but haven't installed yet.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
97 4Runner
83 Pickup
IG: toy_tek
111db is offline   Reply With QuoteReply With Quote
Approximate cost to replace timing belt and water pump osiris3mc 3rd gen T4Rs 47 09-30-2018 01:15 AM
Timing belt + Water pump camofreak 3rd gen T4Rs 19 06-08-2016 03:00 AM
Timing belt/water pump ashbata 3rd gen T4Rs 5 01-10-2016 01:35 AM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
Replace water pump/tri-belt pankers 4th Gen T4Rs 2 04-25-2011 10:49 PM
